Old 02-08-2011, 07:39 PM   #1
Year: 90
Coachwork: Volunteer
Engine: 366
? Insulation????
Guys I been looking around the board And in the gallery. Where is everyone getting the foam insulation from that's being used in the floors, and I seen one that had some on the ceiling in one bus that looked to be squares put together like a puzzle any belongs appreciated. I wanna insulate my floor for sure, I found the red rosin paper locally, even called lowes about the foam board but all they have is the ridged stuff.
Six Four is offline   Reply With Quote
Old 02-17-2011, 01:53 PM   #2
Year: 89
Coachwork: thomas
Engine: 7.3 diesel
Re: ? Insulation????
64, go to lowes and ask for foam core, it very flexible, its 1/4" but you can put it anywhere, its what they put behind vinyl siding...
see my conversion at https://www.skoolie.net/gallery/v/Skoolies/Putters+Bus/
putterspitt is offline   Reply With Quote
Old 02-17-2011, 06:24 PM   #3
lornaschinske's Avatar
Rated Cap: 89
How about pics and links?
http://www.homedepot.com/Building-Ma...atalogId=10053 listed on the website under "sheathings"
http://www.lowes.com/pd_15328-288-15...uantity_sold|1 under insulated sheathing R-Max has the most R-Value per inch thickness
http://www.homedepot.com/Building-Ma...atalogId=10053 Radient Barrier/Reflectix brand
When you compare insulation, you need to compare R-Value for the same thicknesses. And then you can compare costs.
R-Values for :
R-Max 1/2" = 3.2
Foamular (pink) 1/2" = 2.5
Dow (blue) 1/2" = 3.0
Perma R (white crap) 1/2" = 2.17
Fulltime since 2006
Old 02-20-2011, 06:57 PM   #4
Year: 90
Engine: 366
Thanks alot, I noticed my 1990 has some insulation in the ceiling
How much insulation did you add to your bus? TygerCub Conversion General Discussions 8 03-09-2012 02:51 PM
insulation ???? jackling54 Conversion General Discussions 8 12-25-2010 10:42 AM
Insulation TygerCub Conversion General Discussions 7 08-24-2009 06:57 PM
All about insulation ollopa Conversion General Discussions 5 11-15-2006 10:26 PM
Insulation? Father_of_10 Conversion General Discussions 20 02-24-2004 10:10 AM
