Old 06-04-2010, 10:02 AM   #1
Moderator
crazycal's Avatar
Engine: DT408, AT545
Rated Cap: 23 500 gvw
Re: Is It Magic!? New (old) bus fixes itself after 200 miles!
Maybe you had some sticky valves. You should change your fluid if you haven't done so. It seems that is one thing many people neglect. They change their oil every 3000 mile but when you ask them about the tranny, they say they didn't know that it needed to be changed.
I'm hungry!
You Gotta Let Me Fly
Old 06-04-2010, 10:09 AM   #2
Stuff's Avatar
i concur with the above guys. probably something freed up and is shifting like a champ now. Also doing a tranny flush/change will show you some history on the bus as to if it was actually serviced as it should have been and if it was driven hard (burnt smelling fluid)
Old 06-04-2010, 10:23 AM   #3
Moderator
crazycal's Avatar
Originally Posted by cincinnati_kid
Depends on who you talk to. My moms 03 Impala has a sealed transmission. On a heavy vehicle like a bus it is prob a good idea. An automatic trans is a series of controlled leaks so if one of the passage ways was cloged or a check ball was stuck it will shift hard. Prob a goot idea to change it though.
I don't know anything about sealed trannys. I try to service my trannies(transmissions not transvestites) every 20k miles. Replacing trannys sucks and is not cheap. My cars do a lot of idling and go up and down many hills. Not changing the fluid will shorten tranny life.
I'm hungry!
Old 06-04-2010, 11:12 AM   #4
Stuff's Avatar
If you use a quality fluid 20k is overkill but to each his own. I use a high quality synthetic trans fluid in my truck and I tow a 15k trailer all the time through the mountains and I change every 50k and still bright red and no burnt smell
old 91 f150 i got had 250k km on it. had shifting problems and took it to get changed. guy said the marks from the factory were still on the pan for it. it had NEVER been changed. sadly it wasnt soon enough for that tranny and it never did fully recover... would max out on highway at 110 km/hr empty
Old 06-05-2010, 01:56 PM   #5
Stuff's Avatar
yes and no to the shifting. some newer ones get a memory to them and will drive and shift like you usually drive it. this usually applies to the computer controlled ones though.
some heavier shifting is normal but not like 'omg my rear end just fell out" feeling.
Old 06-05-2010, 02:17 PM   #6
Elliot Naess's Avatar
Engine: 5,9 Cummins
Millicent did something similar, and that had to do with the modulator cable. Please have all these things checked by a pro.
60's Magic Chef RV Stove Question.. Skip Heating, Cooling and Appliances 13 01-22-2014 09:34 PM
Magic Bus magic_bus Skoolie Conversion Projects 28 01-13-2013 12:53 PM
Floorplan ideas for the Magic Bus Diesel Dan Conversion General Discussions 6 10-12-2009 08:35 PM
Thedford Aqua magic V - Install question Elliot Naess Plumbing, Water and Waste 5 10-20-2008 09:50 PM
magic bus westport_wayne Everything Else | General Skoolie Discussions 2 04-05-2006 12:57 PM
