Old 08-17-2016, 12:25 AM   #1
Just realized this!!!
I'm building a garage behind my bed in the back of the bus...
If I build it solid, I'm screwed it the fridge goes out, or I want to add different pieces of furniture!
I tend to overbuild everything I touch... If 4 screws will hold it, 6 bolts are better!
I've gotta piece that back wall into sections, so I can break it down... And my 32" pocket doors are a bust too!!!
Old 08-17-2016, 12:43 AM   #2
You overbuild. I overthink...
Sorry about the pocket doors.
BusFiend is offline   Reply With Quote
Old 08-17-2016, 06:06 AM   #3
Why not just have a door from the bedroom to the garage?
Roll Your Own Build Thread
Old 08-17-2016, 08:36 AM   #4
The wall will be fashioned into my headboard....
I'll build the wall and have door hinges and pins on the garage side the I can pop out and remove 40" middle section of wall when needed.
Leaning toward dog eared red cedar pickets on a grey and spackle troweled OSB wall. Or thinned liquid nailed v notch swirl troweled for better adhesion than Sheetrock mud.
Old 08-17-2016, 11:19 AM   #5
onenationundergoat's Avatar
Chassis: Thomas
Engine: International Navistar DT360
Rated Cap: 60
That's funny because we have the same issue. Three walls in the bus, with 22" doors. We had to build the clawfoot bathtub into the bus before the walls. Then when I remodeled the back room and moved around the chest freezer, I inadvertently made the goat pen in such a way that I can't remove the freezer! It died last week and now we have a permanent heavy duty storage bin! Hahahaha
My build thread:http://www.skoolie.net/forums/f11/build-thread-for-haulin-oats-and-goats-11237.html#post113500
A gal, a guy, three cats, two dogs, one rabbit, and one goat, traveling the country together.
onenationundergoat is offline   Reply With Quote
Old 08-30-2016, 08:10 PM   #6
Who says I can't use 6" C Purlin for my bed support?!?!?
Since it was free.... Cheap is good, free is better!
Since it's got to be removable, in case the fridge goes out!
4 pieces total... Won't need center leg support! Wide open underneath.
