Old 04-13-2010, 03:06 PM   #1
Steve's Avatar
Re: Kipor Generators
Looks like the same inverter technology that the Honda uses so it should be quiet.
Old 04-13-2010, 09:44 PM   #2
Stuff's Avatar
are these quiet enough to run at a campsite etc?
Old 05-11-2010, 05:51 PM   #3
lapeer20m's Avatar
i have owned 2 honda eu2ki geni's. I also had the opportunity to play with a kippor. It looks to me to be a near identical clone of the honda. It may not be built to the same high tolerences, but who knows. I started it up and plugged stuff into it just for fun.
according to this http://www.helpcharts.com/decibel-range-chart-info.html: sound intensity doubles every 3 db....so if something is 7 db louder, that is more than twice as loud.
My opinion is that you should go to mayberrys.com and order a honda. They are $899, no tax, free shipping.
Old 05-12-2010, 02:14 PM   #4
lapeer20m's Avatar
i could run my 110 volt wire feed welder on it's lowest heat setting off of a honda eu2k if i turned the eco throttle off. I welded some stuff while at burningman using this setup.
don't forget that kawasaki makes a little larger inverter/geni and or you could buy a honda eu3000 or a pair of 2K's.
Old 05-14-2010, 06:02 PM   #5
Moderator
crazycal's Avatar
Engine: DT408, AT545
Rated Cap: 23 500 gvw
Smitty, if you can get a Honda for $899 like Lapeer said, that's only $120 more than the one on your link. I don't think the difference is enough to consider the Kipor. I have never heard anyone say anything bad about the Honda.
I'm hungry!
You Gotta Let Me Fly
Old 05-14-2010, 10:10 PM   #6
Moderator
crazycal's Avatar
10-4
I'm hungry!
Let's talk about generators willhitch Conversion General Discussions 7 09-15-2014 03:56 PM
DC generators.... jkindt Conversion General Discussions 4 02-20-2010 10:27 AM
Generators Demonknight Conversion General Discussions 7 01-10-2008 04:00 AM
generators lapeer20m Everything Else | General Skoolie Discussions 8 03-30-2005 07:43 PM
generators lapeer20m Conversion General Discussions 1 08-18-2004 04:32 PM
