Old 04-20-2006, 10:39 AM   #1
rayne's Avatar
Year: 1985
Chassis: IHC
Engine: 9.0
Rated Cap: 76
leaky trans
my tranny has a slow leak I think its probably just a gasket but could this be aa serious problem?
not all who wander are lost
rayne is offline   Reply With Quote
Old 04-21-2006, 08:51 PM   #2
rayne's Avatar
Year: 1985
Chassis: IHC
Engine: 9.0
Rated Cap: 76
tranny questions
I've read you shouldn't buy a bus with a leaky tranny but too late for that anybody have any tips?
Old 04-21-2006, 10:35 PM   #3
phillbus914's Avatar
How bad of a leak is it?
Maybe dont worry about it, just keep an eye on the fluid. I have a vary slow power steering fuild leak & a coolant leak that I dont worry about.
My Old Bus :(
Old 04-21-2006, 10:41 PM   #4
leaky tranny
maybe check and see if you can tell where its leaking. if its leaking where the driveline goes into the rear out put shaft on the tranny its probably just the rear seal. maybe the tranny fluid pan gasket is leaking ???? just a couple ideas. good luck john
westport_wayne is offline   Reply With Quote
Old 04-24-2006, 01:38 PM   #5
Eric von Kleist's Avatar
Year: 1985
Coachwork: ThomasBuilt
Rated Cap: 60
I seem to put about a gallon of ATF in mine whenever I move it, but I think it's all dripping out around a leaky pan seal. I think. I keep telling myself. I hope.
Can you burn tranny fluid in a diesel engine? It may soon become cost competitive with diesel fuel....
Eric von Kleist is offline   Reply With Quote
Leaky oil pan? Seeria Mechanical and Drivetrains 4 06-01-2022 02:20 PM
How to seal leaky windows !!! heath692 Conversion Tutorials and How-to's 44 12-13-2020 03:12 PM
Replacing A Leaky Bus Window lornaschinske Conversion General Discussions 3 08-15-2012 06:32 PM
Got a leaky roof? No problem! Stuff Everything Else | General Skoolie Discussions 4 07-21-2010 11:53 PM
Motor and trans info on a 1979 ford gas motor auto trans highvoltage21733 Conversion General Discussions 3 10-28-2005 09:31 AM
