Old 06-15-2014, 11:00 PM   #31
Re: Leveling blocks
nat, perhaps you could clarify your thoughts as to why the "little compressor" that Lorna speaks of won't work. If you'll include remarks including CFM's, static pressure and valving for example, your comments will help folks understand how it is you know all about pneumatics (and probably hydrolics) and why the little compressor won't work etc.
Old 06-16-2014, 08:34 PM   #32
Chassis: B3800 Short bus
Re: Leveling blocks
This thread is turning into all sorts of fun
Old 06-16-2014, 09:03 PM   #33
Re: Leveling blocks
Old 06-17-2014, 06:23 PM   #34
Stu & Filo. T's Avatar
Coachwork: Crown / Pusher
Re: Leveling blocks
Ok Ok,,, Group Hug
Old 06-17-2014, 07:02 PM   #35
Scooternj's Avatar
Chassis: International 3000RE
Engine: T444E/AT545
Rated Cap: 75
Re: Leveling blocks
Originally Posted by allwthrrider
Ok Ok,,, Group Hug
Properly edited
Captain Obvious on deviantArt
Old 06-24-2014, 09:24 PM   #36
Re: Leveling blocks
is it just me, or did anyone else notice that some ones posts have disappeared ?
Old 06-24-2014, 10:42 PM   #37
freakn's Avatar
Re: Leveling blocks
I think he may have been banned. I missed his recent posts.
Living the dream in the Kootenays
freakn is offline   Reply With Quote
Old 06-25-2014, 09:08 PM   #38
Re: Leveling blocks
Originally Posted by Scooternj
Sometimes it makes you wonder about people.
Yesterday or the day before, I saw a pickup truck parked behind an empty 12-wheel dump truck at a stop sign on a slope. Traffic was going out and around them. The drivers' doors were marked with the same company.
A couple of people were sitting or standing by the guide rail, and someone (a mechanic?) was crouched between the dump truck and the pickup, talking on a flip-phone. I noticed that there was a bottle jack underneath near the rear pumpkin, and I could not be sure if he was trying to lift the rear axle.
There was not a chock block behind any one of the 8 tires I could see (with no load, the middle 2 tires were in the air). If I were a cop, and called to investigate the dump truck rolling back and executing the cell phone user, I would write it up as a suicide and not an accident.
Old 06-25-2014, 09:16 PM   #39
Scooternj's Avatar
Engine: T444E/AT545
Rated Cap: 75
Re: Leveling blocks
Old 06-27-2014, 07:29 AM   #40
Re: Leveling blocks
Back on topic my skoolie-ites
So we use a combo of 2x6 wood and mostly fiberglass grating that has 10 grit texture on one side
These are scrap from when Lisa worked at fibergrate 15 hrs ago.
They are made to replace/upgrade steel catwalks, check out local fiberglass shops...because you might luck out, shipping would be a killer
If ground is soft, wood goes down first, then fiberglass they are both about 1-1/2 thick and as wide as the rear duals....I will not put all the wt on one tire(even though they could probably handle the wt I want the friction/traction and stability of two tires on the ground)
I reckon i need a picture for this thread....give me a few hrs or days....waiting to go into chair soon
Leveling your bus... ezbme Conversion General Discussions 9 10-25-2009 02:26 PM
Does anyone have a leveling system ? Kirbystud Conversion General Discussions 3 08-27-2009 08:54 PM
Skoolie leveling KC10Chief Everything Else | General Skoolie Discussions 4 09-30-2007 12:17 AM
leveling jacks? The Wanderer Conversion General Discussions 33 03-14-2007 01:52 AM
Bus Leveling rabiznick Conversion General Discussions 8 11-08-2004 05:24 AM
