Old 04-15-2012, 09:56 AM   #1
frank-id's Avatar
Looking for any repair for an ABS fuel tank.
I have cleaned, roughed and heated a gasoline fuel tank. I have used epoxy, super glue, ABS pipe solvent and with no success. Anyone have a good repair??? This tank is for a JD garden tractor with no replacement tank. Frank
Old 04-15-2012, 02:22 PM   #2
lornaschinske's Avatar
Rated Cap: 89
Re: Looking for any repair for an ABS fuel tank.
Are you SURE it's ABS and not black poly? Sounds like that black poly. I've heard of a repair kit that will patch poly, just not seen it in stores.
TAP Poly-Weld. If you go with this, PLEASE let us all know if it works.
Fulltime since 2006
Old 04-15-2012, 03:47 PM   #3
Coachwork: Ward Genesis
Engine: DT466/MT643
Have you tried JB Weld? I have seen it work on plastic radiators, glove boxes, and pipes. It's impervious to gasoline.
Jarlaxle
Old 04-16-2012, 10:46 AM   #4
to make sure its abs if not listed on tank somewhere is to cut a small piece and do a burn test... i normally weld plastic back together and reinforce the broken area whilst doing so.
Old 04-16-2012, 12:41 PM   #5
Stuff's Avatar
JB weld should be okay for a lawnmower tractor
Installing a different tank mount and/or fuel tank jazty Conversion General Discussions 16 09-15-2014 05:42 PM
Fuel tank capacity Joseph Cabot Conversion General Discussions 6 12-14-2009 12:36 PM
If you run the fuel tank dry newbusser Conversion General Discussions 4 05-01-2009 10:08 PM
wvo fuel tank on my bus mike Alternative Fuels | Electric, Propane, Wood & Biofuels 1 01-06-2009 11:16 PM
Fuel Tank Mounting dlor1 Conversion General Discussions 5 05-30-2008 09:48 PM
