Old 09-27-2004, 05:49 PM   #1
rabiznick's Avatar
Send a message via AIM to rabiznick
Low tech refridgeration
Since bus converters seem to be a very ingenious and creative lot, I thought you all might enjoy these two links. Just may be the answer for you serious boondockers out there.
The first is a small bit of history, the second is some homebuilt examples of probably the lowest tech refridgeration system ever invented.
http://www.refresearch.com/m-icyball.html
http://www.ggw.org/~cac/IcyBall/HomeBui ... Built.html
I'm sure some of you probably already know about this technology, but for those that don't, it's pretty entertaining stuff.
Enjoy!
rabiznick is offline   Reply With Quote
Old 09-27-2004, 06:44 PM   #2
Eric von Kleist's Avatar
Year: 1985
Coachwork: ThomasBuilt
Rated Cap: 60
Here's something similar
That is SO extremely cool!! (pun intended)
Here is something similar:
http://homepower.com/files/solarice.pdf
Same principle, but using a parabolic trough solar collector for power (and not nearly as compact.)
Extremely neat item!
You should check out the Remote Living section of the Otherpower discussion board at http://www.fieldlines.com
Mostly it is "build your own homemade electrical generation and storage systems" stuff, but there are other neat things there, too.
I think a bus with a deck on top could have swing out solar collectors with an icemaker built in. It would be neat, anyway....
Old tech revisted: Steam Drive? Steve Alternative Fuels | Electric, Propane, Wood & Biofuels 3 01-13-2014 08:18 PM
windshield wiper tech bansil Conversion Tutorials and How-to's 2 07-03-2013 10:18 AM
Anyone ever use Hy-Tech#85 Barrier Coat bapos Conversion General Discussions 1 05-05-2013 10:16 PM
Hi-tech Insulation Gulfcoast Conversion General Discussions 1 03-24-2012 07:14 PM
EcoRoamer: The High-Tech, Zombie-Proof Survival RV Steve Everything Else | General Skoolie Discussions 3 04-13-2010 10:40 PM
