Old 05-30-2012, 12:48 PM   #1
Moderator
crazycal's Avatar
Engine: DT408, AT545
Rated Cap: 23 500 gvw
Manual transmission with a 2 speed rearend
Does anyone have a manual transmission with a 2 speed rearend? What is it like to drive? Does it help with mileage?
I'm hungry!
You Gotta Let Me Fly
Old 05-30-2012, 03:16 PM   #2
Re: Manual transmission with a 2 speed rearend
i had them in the first two conventional internatiol skoolies i had.. drove fine. used high range all the time on the freeways and i could easily go 65 with them.
Old 05-30-2012, 06:16 PM   #3
Moderator
crazycal's Avatar
So you don't have to go low to hi as you run through the gears?
I'm hungry!
Old 05-30-2012, 07:49 PM   #4
no. unless you have a heavy load, you can leave in hi range and start off there. in my dads old service trucks 50 yrs ago which were loaded to 28k, we had to use low range to start off with = in the gas engined ones. you can easily tell if you have to use low range on take off... in the 2 skoolies with international v8 engines, mostly i used high range.. exc in places like hills...
Old 05-30-2012, 09:12 PM   #5
Moderator
crazycal's Avatar
Interesting. I need to find one to drive.
I'm hungry!
Old 05-31-2012, 08:59 AM   #6
Year: 94
Coachwork: b/b
Chassis: tc2000
Engine: 5.9
i have a 2 speed rear in my b/b with a 545 auto trans ,i use the low when pulling hills,but most of the time i run it in high...
5.9 cummins 545 auto,two speed rear...works great......11,22.5 tires
keith is offline   Reply With Quote
Old 05-31-2012, 09:33 AM   #7
Moderator
crazycal's Avatar
A 2sp with an auto. That's cool. Does it help with mileage or hills.
I'm hungry!
Old 05-31-2012, 06:41 PM   #8
Stuff's Avatar
dad had an old 70's F500 and one place i worked for had an international van truck both with two speed rear ends. Dad's truck he only used it for 3rd,4th,5th to split high/low and could only get 80km/hr out of it down the highway cause it was so heavy (crane truck). the Int van truck i drove the idiot that trained me didnt even know how to drive it.. he would just put it into low while driving down the road then was like "what's that rattling sound??"....
Old 05-31-2012, 07:14 PM   #9
Year: 94
Coachwork: b/b
Chassis: tc2000
Engine: 5.9
11mpg in the mtns and 12,13 mpg on the flat land at 60mph....
Old 05-31-2012, 08:22 PM   #10
turnbotank's Avatar
Keith, did your bus come like this or was this an upgrade? I have been looking at buying a BB with a cummins and auto but was worried about the gearing and highway usage.
turnbotank is offline   Reply With Quote
Old 06-03-2012, 12:43 PM   #11
Moderator
crazycal's Avatar
Didn't get the bus. It sold for almost $6000. Bummer.
I'm hungry!
Old 06-03-2012, 02:30 PM   #12
Year: 94
Coachwork: b/b
Chassis: tc2000
Engine: 5.9
i set the bus up my self ,it had a 478 rear an change it to a 375 rear and than add the two speed, i still have a bird with a 478 rear that iam going to put a two speed on it and have another bus to sell ,it a 93 tc2000 72 pass..
Old 07-22-2015, 08:23 AM   #13
slideforlife's Avatar
Engine: dt466/5 speed spicer
there's another thread here discussing this that says shifting the rear gears on the fly breaks it- i'm taking it to mean that means you have to start off either high or low from a stop
slideforlife is offline   Reply With Quote
Old 07-22-2015, 01:28 PM   #14
Alan N's Avatar
Year: 1975
Chassis: Gillig
You can shift them on the fly.
The people I work with can break any thing, they haven't broke a 2 speed yet.
Alan N is offline   Reply With Quote
Transmission? Auto or Manual NWade Mechanical and Drivetrains 4 12-20-2014 01:52 AM
2 SPEED REAREND MRFUNKTASTIC GM | Chevrolet Drivetrain 6 01-06-2014 10:01 AM
Good deal on a 9.0 International w/ 5 speed manual Coma Mechanical and Drivetrains 0 08-06-2010 05:14 PM
Transmission, NEED MORE SPEED BrutalBus83 Ford Drivetrain 7 09-14-2009 04:53 PM
WANTED: BUS WITH A DT466/MANUAL 5 SPEED TRANS lapeer20m Classifieds | Buy, Sell, Swap 7 08-10-2005 02:31 PM
