Old 10-08-2010, 10:13 PM   #1
Re: More about the tin-foil called "vehicle tracking"
At least the mechanic wasn't in jeopardy if he had left the modules alone.
About 20 years ago, during the "Miami Vice" drug lord era, I used to read some aviation maintenance newsletters. Aircraft that fly IFR or near large cities or airports with towers require transponders, which "Squawk" back a code on microwave when the aircraft is hit by radar. The code is issued by air traffic controllers, and dialed in by the pilots. They can also be turned off, or set to special codes such as "Mayday," "Hijack" or "VFR navigation."
Mechanics on the Gulf Coast were finding some aircraft with control yokes that were sticking. When they got under the instrument panel, they found black boxes spliced into the wiring harnesses and held up with zip ties. In the cases that popped up, the boxes were dragging on the moving parts of the flight controls. These black boxes were a second transponder with a pre-set code designed to show the position of the aircraft whenever the battery switch was on, regardless of the setting of the main transponder. Any twin-engine aircraft in the area might have gotten a black box, regardless of ownership or use.
An aviation mechanic has to sign off with his/her license number on any work, and certify that an aircraft is airworthy to return to flight. If they removed, tampered with, or told the owner that there was a black box, they could be arrested for interfering with a federal investigation. If they refused to sigh off on the aircraft, they would have to explain why it was unsafe. If they signed off on an aircraft knowing the flight controls were binding and unsafe, and there was an accident, they could face all kinds of deep doo-doo. Catch 22, indeed.
Old 10-09-2010, 10:35 AM   #2
lornaschinske's Avatar
Rated Cap: 89
I would say that it was obvious that they wanted it found. We knew undercover drug cops in FL and they would say that sometimes they would let folks "find" tracking devices as a warning. Perhaps that guy who found the device has a friend who is about to do something stupid. Don't you think he will be watching his friends a little closer in the future? Like I used to tell a good friend of mine about her pot-smoking boyfriend... as far as the law is concerned, you are guilty by association! Don't ask me to bail your butt out of jail when they pick BOTH of you morons up for possession.
Fulltime since 2006
Old 10-10-2010, 11:21 AM   #3
Coachwork: Ward Genesis
Engine: DT466/MT643
I might have tossed it into a pond, or hauled it to the scrapyard and had them run it through their crusher & baler.
But my car is in a garage at home & a secured lot at work.
Don't sign off on it..."there is "something hanging up" the controls and I can't seem to find what." Let the owner figure it out from there.
Jarlaxle
1986 Intl/Thomas Conventional, DT466 5speed, "Big Blue Bus" thrash Skoolie Conversion Projects 8 08-25-2013 11:57 AM
"Short" bus or "Regular" bus? TygerCub Conversion General Discussions 11 03-03-2012 12:37 PM
++SOLD++ 1989 TC2000 FE (Calif. CLEAN title, as "MH") chev49 Classifieds | Buy, Sell, Swap 1 02-18-2012 12:10 AM
"Tutorial" and "How To" internal error dunnwright Conversion General Discussions 6 11-16-2010 07:02 AM
