Old 03-08-2018, 10:27 AM   #1
Motor help
Opinions on a s1754 v8 diesel it would on a short bus
Anything helps
Reliability
Power
Efficiency
Problematic
Mpg
Just want to know more it would be on an 89 short bus
Lherrlinger is offline   Reply With Quote
Old 03-08-2018, 11:57 AM   #2
Chassis: Bluebird
Engine: 5.9 Cummins/Allison
Rated Cap: 74
Being an S series and V-8 I am presuming a 6.9l although more info would help can't tell by your description wether it is an automatic or manual transmission can't tell you much without knowing a few things. 6.9 l very reliable but in a non turbo configuration not highly powered.
Gdog 5651 is offline   Reply With Quote
Old 03-08-2018, 01:54 PM   #3
Motor
It’s an 89 v8 automatic international
Old 03-08-2018, 01:55 PM   #4
I haven’t gotten the vin yet as soon as I do I’ll let you know
Old 03-08-2018, 01:58 PM   #5
7.3 liter 7300
Old 03-08-2018, 04:09 PM   #6
Chassis: International 1753
Engine: 6.9 International
7.3 idi and 6.9 idi are fairly similar engines. Both will be less then 200hp which is low compared to today's standards. The positive is that they run forever with basic maintenance taken care of.
Being a shorty, with that engine, you most likely have an at545. It's an alright trans but better options are available.
What else would you like to know?
diesel, help me, international, motor, short bus
