Old 05-19-2017, 06:18 AM   #1
BriteLeaf's Avatar
Chassis: Carpenter
Exclamation My bus quit starting ;-(
Can anyone tell me why my bus decided one day to quit starting? Batteries are fully charged, but when I turn the key, the engine doesn't try to turn over. It clicks one time and it is done. Any help would be greatly appreciated.
BriteLeaf is offline   Reply With Quote
Old 05-19-2017, 06:40 AM   #2
Njsurf73's Avatar
Chassis: Bluebird
Engine: 5.9 Cummins 24v
Rated Cap: 72 pax
Did you make any electrical changes. If you can find the starter tried jumping 12-volt directly to the starter to make sure that is not the culprit. If the starter turns over follow the wires back to solenoid and jump the solenoid to see if that might be the culprit. If it's not the starter or the solenoid. check ignition switch.
If you changed anything electrical, put it back and try that first.
Old 05-19-2017, 08:03 AM   #3
johnbloem1974's Avatar
Coachwork: Crown by Carpenter
Rated Cap: 16
With the "one click", I immediately think of some sort of safety interlock or an emergency window. Sometimes that will happen, even without alarms and buzzers. Check emergency windows and hatches 1st as that is the easiest thing....
johnbloem1974 is offline   Reply With Quote
Old 05-19-2017, 08:14 AM   #4
+1 That's exactly what I was thinking.
Iheartbus is offline   Reply With Quote
Old 05-19-2017, 05:09 PM   #5
BriteLeaf's Avatar
Chassis: Carpenter
Problem solved...
I'm an idiot. The bus was not in neutral. It looked like it was, but upon closer inspection, I determined that it was actually in reverse. Anyway, thank God it was an easy fix =)
Old 05-19-2017, 06:56 PM   #6
Robin97396's Avatar
Oh, so it was in Park.
Robin
Nobody's Business
Old 05-19-2017, 07:21 PM   #7
Seems every day we get one of these!
Glad its starting for ya OP.
