Originally Posted by Adrianp918
so i have been noticing that i see weight plaques that say certain weight on front and then back axels
and then the gvwr is like 28,000 lbs
my question is the gvwr total weight with all contents and weight that it can carry or how does that work
Gvwr is the max weight allowed. So in your example 28k lbs, you shouldn't exceed that. That includes everything from fuel, water, stuff inside the bus, passengers etc. The total weight.
Also you have to be careful not to exceed the weight rating of the axles. You could be under 28k lbs (less than gvwr) but if you had all the weight on the back axle, say 23000lbs you could be exceeding that weight limit of that axle.
Sent from my Nexus 6P using Tapatalk
