Old 06-18-2016, 06:12 AM   #11
Yes, check self-storage places that have boat and RV parking but $30/month with them is unlikely. What I also found is even if they look half empty alot of times they're all rented out, people still keep paying for the space so they don't lose it come next fall/winter. May also check with local semi truck and trailer companies, since they may have large lots for their fleet or the vehicles they service. I was able to park at the company lot that was going to do my paint and body work. Also had a good lead with a local mobile home dealership, they rented out parking and in my area they had the best price at 45/mo. Just a few options outside of the ordinary. Of course if you have a friend who has land out in the country I think this is always best.
jake_blue is offline   Reply With Quote
Old 06-18-2016, 06:46 AM   #12
Chassis: International S3800
Another thing to think about is no matter how much sanding sealing and painting you do your bus probably still leaks a little water , or will again somewhere ESP in heavy rains.. If you drive it regularly this is not as big issue as you blow air through everywhere and dry it out but of its parked that's how moisture issues start. So it may be worth the extra few bucks to get a covered space for longevity sake. The current and final place where mine is have electricity with timers so you can periodically charge but not overcharge your batteries when stored.
Old 06-18-2016, 11:26 AM   #13
Nice to finally see another member in my neck of the woods!
That's a really, really nice bus. Doesn't look like it ever saw service as a school bus judging by the lack of reds and no stop arm. Also 57K miles!!
Old 06-18-2016, 11:47 AM   #14
boojiewoojie's Avatar
Chassis: RE300
Engine: DT466E (250h.p.)
Rated Cap: 81
Did you notice it's been painted in the past year and there's yellow peeking through? Also did you notice the little hole right below and behind the driver's window? Probably where the air hose was for the stop sign. Did you notice the rust at the base of the seats? Doesn't necessarily mean the bus is rusted out but it's something that needs to be looked at.
I'm not saying it's a bad bus but for $7000 dollars it needs to be really nice.
Right down the road from you are dealer buses cheaper than that: Used 1998 International AMTRAN - Near Kankakee IL - Midwest Transit
Here's one with A/C: Used 2001 International AMTRAN - Near Kankakee IL - Midwest Transit
Daddy, can we go on a trip again??
'85 Thomas SafTLiner RE
3208 NA CAT MT643
boojiewoojie is offline   Reply With Quote
Old 06-18-2016, 11:56 AM   #15
Coachwork: IC
Chassis: CE300
Rated Cap: 32
I saw that, too. Was thinking the same thing.
That mileage would be highly suspect if the bus has been used for two purposes already in life.
Roll Your Own Build Thread
Old 06-18-2016, 01:26 PM   #16
Chassis: RE300
Rated Cap: 81
Agreed. It is possible, but don't let the owner b.s. you. See if there's a hobbs hour meter. If the hours are under 2000 probably around 1600 then yeah, the mileage may be right.
If there's no hour meter I would want to see paperwork. Sometimes the electronics go out on the bus (like the speedometer stops working) and the odometer will stop working also.
3208 NA CAT MT643
Old 06-18-2016, 05:10 PM   #17
Coachwork: IC
Chassis: CE300
Rated Cap: 32
Or sometimes the whole gauge gets swapped out.
Old 06-18-2016, 05:20 PM   #18
in most if not all states the bus and / or title must be tagged if the odometer is replaced .. if ab us comes from an owner and the title states accurate odometer and it can be proved the gauge cluster was replaced.. there are legal implications...
if the guage cluster has been replaced.. most all companies that rebuild them place their sticker on the cluster in a couple places and usually the date the cluster was rebuilt or shipped.. so you have an ideao f the cluster is dated 2004 and the bus is a 1995 say that the odometer is out of date... however you usually have to pop the cluster loose to see the tag.. Busses with low mileage do happen... esp handi-cap busses... as they were typically low capacity and high priced, many school systems used them only yo transport the handicap students which were not on a normal route typically.. so mileage could be very low on those type busses..
Old 06-18-2016, 06:06 PM   #19
I didn't look that closely - didn't see the yellow paint there
As for seat frame rust, we have 2016 Bluebirds that already have rust on the frames. Combination of poor quality paint and wet boots during the winter.
Old 06-18-2016, 07:20 PM   #20
Carytowncat's Avatar
I've seen 03 bus with 100k miles for $35oo. That price just seems steep. It may be fair but it sure ain't no good deal.
