03-11-2007, 05:04 PM
Moderator
Engine: DT408, AT545
Rated Cap: 23 500 gvw
Opinion time.
I would like some feedback about the two pictures, not about my poor use of the editing software. Which design do you think looks better. What about function. I am not sure it would be a good idea to skin the whole back half of the bus.
Design #1.
Design #2
The black is supposed to be new skin.
03-11-2007, 05:26 PM
If the rear section is going to be a bedroom, I'd leave the windows there like in the first picture. There is something to be said for not having to use your battery powered lights at 5:00 pm in July. You can insulate a window against heat with tint, window quilts, etc, but you can't make a skinned over window translucent when you need just a little light to find your shoes early in the morning or late at night.
03-11-2007, 09:46 PM
I have to agree....I don't like any light when I'm sleeping, but I'd rather have windows there when I need them. I can use shades, blinds, and curtains to take care of unwanted light...
*Cliff*
...Your home has brake lights
1994 Jeep Grand Cherokee
Chesapeake, Virginia
03-11-2007, 10:58 PM
Year: 1985
Engine: 366 propane
Rated Cap: 56
ummm, is it just me or is that air conditioner backwards?
-Richard
03-12-2007, 12:08 AM
Moderator
Beats me. I never looked at or touched it. If I can, I will take a picture and post it. Then you can tell me.
03-12-2007, 09:09 PM
Good catch, it certainly does look like it's backwards!!
*Cliff*
03-12-2007, 09:56 PM
I would go with design #1 and turn the front AC unit around as well as add another one in the back.
Jeff
95 IH 72 passenger transit school bus w/ DT466 and 545 Allison.
79 IH Scout II/392 (0.030 over) Hamilton Injected/727/D300/Full size axles/36" Swampers/Lockers/OBA/38 gal Custom fuel tank, roll bar, tube doors.
03-12-2007, 10:06 PM
Moderator
Boy you guys are really stuck on the a/c thing.
03-13-2007, 04:36 PM
Moderator
Pablo, I think the lines on your bus would be much cleaner if you took that right rear door out and closed it in. I also know someone who would take that door off of your hands.
03-13-2007, 10:55 PM
Year: 1985
Engine: 366 propane
Rated Cap: 56
#1, I think it looks slick. If you put rv windows in the rear it might be a bit more comfy.
-Richard
03-16-2007, 09:42 AM
Moderator
Here is a picture of the a/c. I hope it's not backwards. I would hate to drive the bus backwards to get the a/c working.
03-16-2007, 01:03 PM
Year: 1985
Engine: 366 propane
Rated Cap: 56
Yes, it is backwards.
-Richard
03-16-2007, 08:30 PM
VERY backwards!! The pointy end suppose to go to the front!
I imagine if you move that thing at hiway speeds and that condensor starts taking on air it's likely to catch more air than it can handle and blow right off of there!!
On the good news side, all you gotta do is drop the interior panel then unbolt it and turn it around. Only four bolts hold that thing in place!!
*Cliff*
