Originally Posted by Lherrlinger
Floor, I have treated plywood down above sheet metal, I plan on staying away from cold so don’t need too much insulation but any opinions on flooring would help. I’m 6 feet tall and my bus is 6feet 1” so I don’t have too much room to go up.
Hardwood? Laminate? Rhino lined? Carpet?rubber?
If I wasn't going to insulate, I would probably pick automotive carpet which is fairly low knap, and would help a little with noise. without any padding, it will probably feel only slightly better than the plywood.
If I had (cheap) access to that rubber they use in horse stalls I might consider it, as I assume its like walking on antifatigue mat, and I assume rubber would cut down the conductive heat loss from the floor. But i would guess that horse stall stuff is expensive. Maybe if you had free access to an old conveyor belt, might be another option for rubber on the floor.
