Other uses for Bounce the fabric softner
Subject: Good uses of Bounce
>>> > Bounce:
>>>>>> > > > >And all this time I've just been
>> putting Bounce in the dryer. Check out
>>>>>> > > > >these other possibilities.
>>>>>> > > > >1. It will chase ants away when you
>> lay a sheet near them.
>>>>>> > > > >2. It takes the odor out of books and
>> photo albums that don't get
>>> > opened
>>>>>> > > > >too often
>>>>>> > > > >3. Repels mosquitoes. Tie a sheet of
>> Bounce through a belt loop when
>>>>>> > > > >outdoors during mosquito season.
>>>>>> > > > >4. Eliminates static electricity from
>> your television screen. Since
>>>>>> > > > >Bounce is designed to help eliminate
>> static cling, wipe your television
>>>>>> > > > >screen with a used sheet of Bounce to
>> keep dust from resettling.
>>>>>> > > > >5. Dissolve soap scum from shower
>> doors. Clean with a sheet of Bounce.
>>>>>> > > > >6. Freshen the air in your home. Place
>> an individual sheet of Bounce
>>>>>> > > > >in a drawer or hang in the closet.
>>>>>> > > > >7. Prevent thread from tangling. Run a
>> threaded needle through sheet
>>>>>> > > > >of Bounce before beginning to sew.
>>>>>> > > > >8. Prevent musty suitcases. Place an
>> individual sheet of Bounce inside
>>>>>> > > > >empty luggage before storing.
>>>>>> > > > >9. Freshen the air in your car. Place
>> a sheet of Bounce under the front
>>>>>> > > > >seat.
>>>>>> > > > >10. Clean baked-on foods from a
>> cooking pan. Put a sheet in a pan, fill
>>>>>> > > > >with water, let sit overnight, and
>> sponge clean. The anti-static agent
>>>>>> > > > >apparently weakens the bond between
>> the food
>>>>>> > > > >11. Eliminate odors in wastebaskets.
>> Place a sheet of Bounce at the
>>>>>> > > > >bottom of the wastebasket.
>>>>>> > > > >12. Collect cat hair. Rubbing the area
>> with a sheet of Bounce will
>>>>>> > > > >magnetically attract all the loose
>> hairs.
>>>>>> > > > >13. Eliminate static electricity from
>> venetian blinds. Wipe the blinds
>>>>>> > > > >with a sheet of Bounce to prevent dust
>> from resettling.
>>>>>> > > > >14. Wipe up sawdust from drilling or
>> sand papering. A used sheet of
>>>>>> > > > >Bounce will collect sawdust like a
>> tack cloth.
>>>>>> > > > >15. Eliminate odors in dirty laundry.
>> Place an individual sheet of
>>>>>> > > > >Bounce at the bottom of a laundry bag
>> or hamper.
>>>>>> > > > >16. Deodorize shoes or sneakers. Place
>> a sheet of Bounce in your shoes
>>> > or
>>>>>> > > > >sneakers overnight.
>>>>>> > > > >17. Golfers put a Bounce sheet in
>> their back pocket to keep the bees
>>>>>> > > > >away.
>>>>>> > > > >Print and keep on file or pass it
>> around !!
