Old 09-18-2017, 07:52 PM   #1
Paint
Has anyone used Sherwin Williams Kem 400 to paint their bus?
If so did you use a primer or binder? What color?
Thanks, Steve
tailor is offline   Reply With Quote
Old 09-18-2017, 09:16 PM   #2
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
Nope. Have a price/gal?
KEMŪ 400 Enamel is a general purpose,
short oil alkyd, high gloss enamel.
It is ideal for interior and exterior application
for OEM finishing or refinishing of
industrial, construction, and agricultural
equipment as well as a wide array of
general metal applications.
KEMŪ 400 Acrylic Enamel
For improved exterior color and gloss
retention, faster drying, sharper gloss,
and improved block resistance in stacking,
a 10% addition of Acrylic Modifier,
V70V411, may be added to KEMŪ 400
Enamel.
KEMŪ 400 Urethane Enamel
For increased chemical and abrasion
resistance, improved hardness, sharper
gloss, and better gloss and color retention,
KEMŪ 400 Enamel may be catalyzed
at an 8:1 ratio with KEMŪ 400 Exterior
Catalyst, V66V1020, prior to reduction.
Drying times are slightly faster.
Addition of catalyst eliminates the critical
recoat time. Working potlife is 8 hours
maximum, at room temperature. Catalyst
contains isocyanates, read label
cautions on V66V1020 before use.
Advantages:
• High Gloss
• Good exterior color and gloss retention
• Good one coat protection
• Fast air drying
• Good flexibility and film toughness
• Available in a broad range of colors.
• Ideal for large components because
of longer open time and wet-in of
overspray
• Ideal system for horse trailers, farm,
garden, and construction equipment
and industrial machinery and equipmen
Old 09-18-2017, 10:01 PM   #3
I went to an auto paint supplier ($120 per gallon) s and was explaining about painting my bus. They recommended contacting Sherwin Williams industrial. Spoke to the salesman and he said that this was used by city of Phoenix for heavy equipment and by the army. Obviously very durable and about $65 a gallon.
I'm going there Friday to check it out. Wanted to see if anyone had any experience first.
Old 09-19-2017, 07:45 AM   #4
T-Bolt's Avatar
Engine: DT530
I am planning on using Rust-Oleum Professional at $27 a gallon. I did a test spot on my bus and it turned out great.
Sent from my SAMSUNG-SM-G930A using Tapatalk
https://eternitybus.com
T-Bolt is offline   Reply With Quote
Old 09-19-2017, 08:05 AM   #5
Use some hardener with it for long lasting results.
Old 09-19-2017, 08:25 AM   #6
Skipoffools's Avatar
Coachwork: Carpenter (Cavalier)
Chassis: International Harvester
Engine: DTA360
Rated Cap: 63
I almost got that. They make a harder for it too. It seem like a good product, but it was just too pricey for us.
Skipoffools is offline   Reply With Quote
Old 09-19-2017, 08:46 AM   #7
Just used some of that . Sounnds just like it until i check the can. Gave me a discount off another contracto. Paid $35.00 gallon. Didn't quite match the Rusroleum Forest green. Was a little thin in comparison with rustoleum. I and the guy that painted the roof with rustoleum like rustoleum better.
Old 09-19-2017, 08:52 AM   #8
ACamper's Avatar
Let us know how it goes. I am thinking of buying the Sherwin Williams "All Surface Enamel Oil Base" and using a roller.
$65 a gallon they have a 40% sale in a few days.
ACamper is offline   Reply With Quote
Old 09-19-2017, 10:22 AM   #9
Traveling
Rated Cap: '00
Painting is fun !!!
I am 2+ weeks into a paint job- including prep. Prep is where it's at.
Power washed with phosphate detergent.
I hand sanded the entire surface of the bus with #220 lightly- did not break through the paint. Take of oxidation layer. Yes, it takes a long time alone.
Shot a layer of tinted primer- just add few drops of paint to white primer. Gives you idea of color on bus early on.
Shot 3 light, wet coats of rustoleum, blended my own color from white/primaries. Probably have 2 -2 1/2 gallons used so far. Some waste- can't save hardner-activated paint.
Wait 6 months cure, Urethane clear.
Old 09-19-2017, 10:36 AM   #10
Originally Posted by Rusty View Post
Painting is fun !!!
Attachment 15954
DUDE! That's awesome!!!!
Old 09-19-2017, 12:27 PM   #11
tobeamiss's Avatar
Painting is fun !!!
Attachment 15954
that looks beautiful!
oh yes she did!
https://www.skoolie.net/forums/f11/to...-it-16557.html
Old 09-19-2017, 12:45 PM   #12
Traveling
Rated Cap: '00
Thanks, guys. Still a lot of chance to screw it up.
Design is taken from 1970 wanderlodge. I still need to add dark stripe. And finish front...and back...
Old 09-19-2017, 02:09 PM   #13
BowserJournal's Avatar
Chassis: Ford B600
Rated Cap: 20 person
That does look pretty good. What kind of sprayer did you use? (electric or compressor)
"Living Our Own Story"
The Bowser Journal
Watch our adventures by subscribing...
Youtube - bit.ly/TheBowserJournal
BowserJournal is offline   Reply With Quote
Old 09-19-2017, 03:22 PM   #14
Traveling
Rated Cap: '00
Thanks- I used a 60 gal compressor with the $50 Harbor Freight purple gun set.
more on this thread
Old 09-19-2017, 06:34 PM   #15
kem 400
Just left the SW industrial location and the kem 400 won't work for the bus.
It's designed for relatively stationary use and won't hold up on a moving vehicle, unless I go with military grade. Or I could find an old sailor who misses chipping and painting.
I contacted Rustoleum and they recommended Bin 123 as a primer.
Rusty, what did you use for a primer and what for paint?
Your paint looks terrific.
Old 09-19-2017, 08:00 PM   #16
Traveling
Rated Cap: '00
I just used the rustoleum white metal primer as I didn't have rust.
Get the $50 HF purple spray gun and some paint and play with it. Paint some flowerpots or a wagon. You will be a pro in minutes.
Old 09-19-2017, 08:02 PM   #17
T-Bolt's Avatar
Engine: DT530
Attachment 15959
Did you use a line dryer?
Old 09-19-2017, 08:25 PM   #18
What kind of paint, latex or acrylic?
Old 09-19-2017, 08:37 PM   #19
Traveling
Rated Cap: '00
I do have a big inline dryer/filter, but not refrigerated. Not critical for this job.
The biggest water problems I encountered were these:
Water sets under the rub rails and when the blast of air goes by, water rolls down your paint. I used compressed air to shoot the water out every morning- dew counts.
Other water problem was weird- I was wearing nitrile gloves at first and I kept seeing water in weird spots. It was a hot day and it turns out I was leaning on the bus as I sprayed and water inside my glove was squirting out.
Wind is a bigger issue- I use this govt weather site to predict wind/when. Works great for baseball coaching, too!
Rustoleum is oil-based and cannot be tinted using latex tints.
Old 09-20-2017, 11:48 PM   #20
Sweet love that color
Bettytheford is offline   Reply With Quote
