Old 10-04-2012, 03:15 PM   #1
PASSING GAS IN OUTER SPACE
Breath and rectal gases were analyzed during the first and final weeks. Flatus gases varied widely within dietary groups but much more gas was generated with diet S than with F. In the first 12-hour collection, subjects fed S passed 3 to 209 ml (ATAP) of rectal H2 (avg 52) and 24 to 156 ml (avg 69) from the lungs (assuming normal pulmonary ventilation). With F, these values were 0 to 3 ml (avg 1) and 6 to 36 ml (avg 20). Subjects were calmer during the second test. Gas production was lower with S than initially; F values were unchanged. Methane differed idiosyncratically, presumably due to differences in flora. Computed from 12-hour values, maximum potential daily H2 and CH4 are per man: for S, 730 ml and 382 ml; for F, 80 and 222 ml. Volumes would be larger at reduced spacecraft and suit pressures.
Old 10-04-2012, 04:13 PM   #2
crazycal's Avatar
Engine: DT408, AT545
Rated Cap: 23 500 gvw
Re: PASSING GAS IN OUTER SPACE
Thank you for sharing. Did someone hack your account or did you really want to share that with us?
I'm hungry!
You Gotta Let Me Fly
Old 10-04-2012, 04:16 PM   #3
After reading about the development of freon, I was like mmmmmmmmmm
I then befriended google and thought space farts!
And yup...amazing research
so..no hack...I have been called that before tho' and I have a friend named Hack
Old 10-04-2012, 04:28 PM   #4
GreyEagle's Avatar
Talk about need to know info ....... this is it!!!
It should bo a long way in developing the bus of the future.
Laughed so hard I can hardly hold in ..........
GreyEagle
Roll - On...
GreyEagle is offline   Reply With Quote
Old 10-04-2012, 05:12 PM   #5
Accordion's Avatar
Year: 1973
Engine: CAT 1160 V-8 Diesel
Wherever man has conquered in his quest for frontiers new,
I'm glad they always had to do the numbers one and two.
It makes it all so ordinary just like you and me,
To know the greatest heroes, they had to **** and pee.
Donovan Leitch
Old 10-04-2012, 08:34 PM   #6
IC, indeed you could although like propane ( a sometimes used refrigerent) it is flamable. I think it would work best in one of those heat pump things---and you wouldn't need to worry about heating at temps below 40 degrees, when the heat pump can no longer squeeze any heat from the standard refrigerant you just light a match and heat up quick
Old 10-05-2012, 08:50 PM   #7
bapos's Avatar
Chassis: International Amtran RE
Engine: DT466E/MD3060
Would you like to discuss the Montréal Protocol in grave detail? I recently passed my Universal EPA certification so its semi current in my head
Dallas, TX - passing thru - have ?? lornaschinske On the Road | Travel, Trips, Camp Sites, Tailgates 4 07-27-2014 08:22 PM
Passing this on chev49 Classifieds | Buy, Sell, Swap 1 12-20-2012 11:34 AM
Broken outer rear door handle Dain Conversion General Discussions 6 05-16-2012 09:26 AM
Loophole Closed in Bus Passing Law emilybusgirl School Bus News 0 03-30-2011 04:17 PM
Your bus... from outer space! Steve Everything Else | General Skoolie Discussions 3 07-15-2007 09:33 AM
