Old 11-05-2010, 01:06 PM   #1
pickup truck frame rust prevention
Hi all. Haven't been in here in a bit. still a wannabe skoolie owner. maybe someday the wife will see the light and let me buy one (fat chance).
anyhoo, i just bought a 97 ranger pickup. the body/bed look new. the frame/suspension bits, not so much. drove it to work the other day and noticed some suspension noises. got to work, hopped out and noticed a serious lean to the driver's side.
the driver side leaf spring's front mount snapped off. it was rusted to ****! the PO replaced both rear hangers. like a dummy, i didn't look closely at the front ones. the other side don't look no better.
next week i am gonna pop the bed off, replace both hangers and do a little rust prevention work. was thinking of taking a wire brush to everything in site, knock the loose rust off, then hit everything under there with a coat of por 15. i first learned of por 15 on this site and have heard good things about it. the frame has a little surface rust, but nthing like the hangers. is por 15 overkill? would a few coats of much cheaper rustoleum do me just as well? if i go with the por 15, will a qt cover everything behind the cab? don't want to buy too much as i hear trying to store this stuff is a PITA. also, the price break on buying a gallon really isn't that great.
pete c is offline   Reply With Quote
Old 11-05-2010, 07:28 PM   #2
Re: pickup truck frame rust prevention
As you know por 15 is good stuff....but so is Rustoleum. A quart pf truck bed liner might also be an option but I think it costs more then Rustoleum as well.
Abbott is offline   Reply With Quote
Old 11-06-2010, 06:52 PM   #3
i've heard bad things about bedliner used in this application. that if it gets a nick in it, it will actually trap the moisture inside and it will spread worse.
Towing a 4x4 truck (small truck) 4 down Abbott Everything Else | General Skoolie Discussions 13 12-31-2009 02:05 AM
Purchasing a used 4x4 diesel pickup, what's the best motor? Abbott Everything Else | General Skoolie Discussions 11 09-16-2009 06:18 PM
Using car/pickup engine/trans in heavy bus?(ie cad500/th400) nearhomeless Conversion General Discussions 11 05-22-2009 11:02 AM
Frame width the_experience03 Conversion General Discussions 1 04-14-2006 07:31 PM
Corrosion protection/prevention: your inputs, please! Ryan Grimm Conversion General Discussions 2 05-03-2005 08:16 AM
