Old 07-31-2016, 09:49 AM   #11
Originally Posted by turf View Post
the first few times i was unprepared for what happens. its a scary learning curve. now with some practice i'm much better.
1st time descending i-70 was a white knuckle, change your shorts trip. once coming out of rocky mountain national park, i caught the rear brakes on fire.
you cant depend on the transmission or your brakes to slow you down too much, they dont. you just have to go slow, or get a bus with a retarder.
Learning curve you say?
I'm still trying to keep the pedal to the floor... I haven't driven AWE ONE on roads good enough to run wide open. Hopefully one day I can let her get her wings and fly.
Old 07-31-2016, 11:18 AM   #12
Glad I have the retarder then. Even though I don't have many mountains around me
bread519 is offline   Reply With Quote
Old 07-31-2016, 02:32 PM   #13
I have a retarder and even with that it was hard to stop the bus from 55 MPH towing the 3000# toad. Part of the problem is that the retarders shut down at about 30 MPH to keep the engine from stalling and it is that last bit of momentum that is hardest to overcome. I installed a Brake Buddy in my toad and once I learned how to force it to engage, stopping is much better. On mine, forcing the BB to engage requires a quick jab at the brake pedal followed by constant light or heavy application as necessary to get the rig stopped. The bus brakes are ABS. Jack
Old 07-31-2016, 02:45 PM   #14
I've seen a bunch of retarded buses for sale in my search...
BusFiend is offline   Reply With Quote
Old 07-31-2016, 02:48 PM   #15
Originally Posted by bread519 View Post
So getting half the normal mpg towing 3k pounds is normal?
10-12mpg without the trailer is average
I would be wary of the 10-12mpg figures unless you got them yourself. Do you have a baseline trip, without the toad, to gauge by?
Old 07-31-2016, 03:52 PM   #16
Nope that was my first ride home. But I have done extensive research on this particular drivetrain and manufacturer, and the lowest figures I found were 10mpg
We shall see though, I'll be ok with 9 but I bet I can squeeze 10 out of her with some practice
Old 07-31-2016, 07:09 PM   #17
Just remember that once you break 55 MPH, mileage starts to drop quickly. After 55, aerodynamics becomes the largest factor in efficiency and grows very rapidly the faster you travel. That also includes any additional drag your toad adds to the package.
Old 07-31-2016, 09:10 PM   #18
My retarder doesn't cut off till around 10 mph. Maybe they differ between brands.
Old 07-31-2016, 09:12 PM   #19
My bus is 4.78 rear end, so 65 is spinning faster than I would care for. Maybe someday I'll change it, for now I'll cut it down to 55. And you're totally right, this thing is definitely a brick traveling at those speeds
