Originally Posted by BowserJournal
I have to remove all the windows in ours to remove the wall panels. I am not looking forward to it at all.
Not too bad- just have a plan where to place glass before it's out.
With the rubber-seal windows, there is usually a piece of stiffer rubber welting inside the softer rubber seal. Gently pop-it out w/ small screwdriver at seam. Once that is out, the pressure is released and window *should * come out easily. Be gentle on rubber seals as they are pricey.
