The situation regarding bus or RV should be the same. So I will answer from a sticks-n-staples RVer's point of view since we have yet to move into our bus...
Does your bus sweat inside during the cold months because of the heat?
We have single pane aluminum framed windows. The windows do sweat in high humidity times (98% humidity and it's pouring rain) add to that we cover the glass and frames with Reflectix. The frames do sweat. LP dumps a high amount of water vapour into the air when you do something like cook and do not use the stove vent. We have not seen this happen with our LP fired furnace. I suspect because the combustion occurs in a sealed chamber that is vented to the exterior.
Or in the summer months because of air condition ?
the rooftop A/C unit sucks every drop of moisture from the air quite nicely. The window frames sweat slightly during high humidity (98% and pouring rain) with the A/C on. although the outside does at times. But then we have spent alot of time in places like SC upstate (around Lake Keowee and Lake Hartwell where you step out the door at midnight and you "condensate".... same for S GA on Lake Blackshear)
The aluminum frames of ANY window (single or dual pane) is why we are going to use a PVC "wood" for our window trims. The Blue Bird has aluminum framed windows.
We, the wife and I have discussed the possibility of fulltiming after she retires in 2013. Right now her choice of RV's is a 5th wheel.. more room, more inside storage etc. I myself prefer the motorhome version because of the easy set up, pull in park, hookup if available and you're done.
To me, the downside of a fiver is that once you get to your "destination" you have a rather large fuel hog to drive "locally", whereas with a motorhome you can tow a more fuel efficient vehicle to do your local trips in. That said, Our Blue Bird gets better fuel mileage than my Jeep grand Cherokee (10 - 12 mpg)!!!! And the Class C only gets 6 - 8 MPG. I have heard of some motorhomes that get as low as 2 mpg. For us the Blue Bird will be our fulltime home. We consider a sticks-n-staples RV to be several steps down from a skoolie conversion... atleast one that we could put together.
