Old 02-10-2016, 10:36 AM   #1
Quick question, ne answers?
Im very new to this!
Quick question can't
Really find many clear
Tutorial video's on how
To patch up holes in the
Bus from bolts/nuts/screws?
I always see people putting
Something liquid n smearing
It around then sanding it
Down? Is it acrylic or some
Type of bonding? Please let
Me no if anybody has a link
Or what the materials are called
& how to properly do it! Thanks
The B&C Express is offline   Reply With Quote
Old 02-10-2016, 11:29 AM   #2
Me...I welded all of my seat holes. Unless you are using a true commercial grade, high tech adhesive on a properly prepared surface, I would expect to see leaks in fairly short order. And once everything is built on top of the floor...they will be very hard to address later.
Old 02-10-2016, 03:22 PM   #3
Chassis: TC2000 RE
Engine: 8.3l Cummins
At first I thought your question was some sort of poem about acrylic caulk.
The answer is: it depends
If it's in a place where it won't affect you (won't cause a leak or a draft, or won't see it) then just leave the hole. If it's unsightly, you could weld or body fill it.
If it's in galvanized material, welding should be followed up with a covering of cold galvanizing spray on both sides.
Vehicle seam sealer works great as well.
aaronsb is offline   Reply With Quote
Old 02-10-2016, 05:16 PM   #4
Chassis: MVP
Engine: CAT 3116
I used tin caps and glue to seal the holes.
Tin caps:
Grip-Rite 1 lb. Tin Caps-TIN1 - The Home Depot
Glue:
Robot Check
I used that glue because I had some leftover. I'm sure there is better stuff out there, but it seemed to work.
This what it looked like:
Piersg is offline   Reply With Quote
Old 02-10-2016, 07:33 PM   #5
superdave's Avatar
Chassis: thomas
Engine: 8.3 cummins
Rated Cap: 11 window
Tin caps:
Glue:
Robot Check
i did exactly the same, with the same bus.
my build pics
Old 02-11-2016, 02:45 PM   #6
Looks like Braille!
Old 02-12-2016, 10:12 AM   #7
someone glued pennies down
repairing holes in bus
