At first I thought your question was some sort of poem about acrylic caulk.
The answer is: it depends
If it's in a place where it won't affect you (won't cause a leak or a draft, or won't see it) then just leave the hole. If it's unsightly, you could weld or body fill it.
If it's in galvanized material, welding should be followed up with a covering of cold galvanizing spray on both sides.
Vehicle seam sealer works great as well.
Originally Posted by The B&C Express
Im very new to this!
Quick question can't
Really find many clear
Tutorial video's on how
To patch up holes in the
Bus from bolts/nuts/screws?
I always see people putting
Something liquid n smearing
It around then sanding it
Down? Is it acrylic or some
Type of bonding? Please let
Me no if anybody has a link
Or what the materials are called
& how to properly do it! Thanks
