Old 04-04-2015, 03:56 PM   #11
The number one thing to be on the look out is rust.
No matter how inexpensive a bus is, if it has rust it will be a money pit.
The most expensive part of a bus and the hardest to change is the power package. Purchasing a bus with a good engine, a good transmission, and gearing to fit your purposes will cost you much less in the long run than to change stuff out once you purchase your bus.
Unless you plan on getting on the road right away, if the choice is between buses with good tires or bad with everything else being equal go with the one with better rubber. But don't decide on any particular bus based on the rubber. In most cases RV's will have the tires die of old age before they wear out. Good rubber is a plus but should not be a deal breaker.
Don't limit your search to just the NE. There are a lot of buses in the NE but you may find the "perfect" bus for you somewhere else. Traveling some distance for your "perfect" bus may cost you less in the long run.
If you really do not want any electronics you will need to be looking at 1995 and older. 1996 saw some electronics and by 1997 almost everything became electronically controlled.
If there is anything I can do to help, even if it is just to discuss what type of bus would be best you are more than welcome to contact me.
Good luck and happy trails.
cowlitzcoach is online now   Reply With Quote
Old 04-05-2015, 09:14 AM   #12
Thanks Cowlitz that is good advice.
What do you think about the big "avoid electronic" push?
I hear so many mixed messages about the EFI systems.
Is it really that bad or is are there just certain years/models where they were more unreliable? I know in the motorcycle crowd, many guys dont like the EFI systems mainly because they don't like working on computers if they are not working right. Same time ive heard horror stories about the newest california diesel trucks with the advanced emission control. Hard to believe that 20 years of school buses should be "avoided".
From what I have been hearing, the International 466 seems like the engine to get. I was thinking of looking for the DT466 in particular, but are there certain years of the 466E that are good? Hopefully someone can shine some light on this for me.
Thanks again
ozthemost is offline   Reply With Quote
Old 04-05-2015, 11:27 AM   #13
Engine: 190hp 5.9 Cummins
Thanks again
If you can afford to pay a shop to fix your bus, get one with a computer.
If you have to be able to fix it with just basic tools yourself, get a fully mechanical bus.
Old 04-05-2015, 10:09 PM   #14
Good advise Nat. Clint will tackle or try to tackle any vehicle no matter the size & shape; but he is completely over working on my Nissan pickup. Nothing and I mean nothing is as it appears when you get a computer thrown in the mix.
The-Breeze is offline   Reply With Quote
Old 04-06-2015, 08:43 AM   #15
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Rated Cap: Her, me and Molly
Are electronics good? Yes and no.
I've been working on and earning a living working on cars for over 50 years. When I started, unless the engine was physically broke, it wasn't all that hard to get it running with a few inexpensive parts. A service call often just involved adjusting the points, you could "eyeball" it, checking the choke for operation and putting in every other spark plug in firing order. Pretty much everything was able to be taken apart and fixed. A tune up was 10,000 miles or once a year.
First on the scene was electronic ignition, I always worked in independent shops, we didn't have the "factory" test equipment, nor did we have a spare module sitting on the shelf to plug in to see if that fixed the problem. The modules were expensive and unreliable. Many people carried a "spare" module with them. If we did buy something and it didn't fix the problem, it came back off. The factory dealer wouldn't take it back because it was "used", the customer was NOT charged for a part he didn't need.
Next were the many forms of fuel injection, which in my opinion were a huge leap forward. They were kind of "electronic" but relied mostly on air flow and temperature sensors. There wasn't an ECU for the whole engine.Things were getting harder to diagnose, service manuals were hard to get and expensive. Test equipment pretty much was a fuel pressure gauge and a VOM. There was no internet or hot line to call. The parts, though, were getting more and more expensive and less and less repairable.
By this time we had pretty much quit going out on service calls. If it didn't start we called a wrecker.
Todays engines, both gas and diesel, for the most part, last longer, get better mileage, have more horsepower, and are more reliable. When I started out, an engine with 100,000 miles was pretty rare. When everything works right, and for the most part it does, everything is wonderful. When something goes wrong, even the most sophisticated test equipment can't find all that much. It can tell you the general area to look. A good mechanic uses that info to start testing, but there is still a lot of testing that needs to be done, and that gets expensive.
Independent shops are getting pretty rare, just because the cost of information and equipment is too expensive. There are also less and less dealers around. My little town used to have three GM,two Ford and a Dodge dealer. Now, there is just one GM.
I work on my own vehicles, they are both mechanical diesels. My wife has a late model SUV with all the buttons. I fix the mechanical stuff, if and when the electronics go bad we'll probably just buy a different car.
Old 04-06-2015, 10:44 AM   #16
Gotcha, that helps explain a lot. Thank you.
You were saying that the electronic engines will typically run longer, I am assuming this is because overall efficiency and closely controlled combustion that doesn't over-stress the engine.
So, if I were looking at two identical buses, one with a DT466 and the other was a 466E, are there specific mileage and maintenance markers I can look for to make sure proper maintenance was done on each?
What is the expected lifetime in miles of a DT vs the E? How many is too many? When should I expect to have to rebuild one?
This is going to help a lot when I start to actually have to pick my pony, there are so many variables that I am sure its maintenance and overall hours on the road will have a significant effect on its future cost for me. I just dont know exactly what to to look for.
I've also been recommended to aim for these 5 speed transmissions:
Allison 643 or MD3060
Do all the bus experts in here agree?
Thanks!
Jeff
Old 04-06-2015, 10:59 AM   #17
Coachwork: IC
Chassis: CE300
Rated Cap: 32
The 643 is only a four speed and no od.
But I'd rather have it since it doesnt have a computer.
My all mechanical DT466 has a quarter million miles on it and runs as good as new. NO smoke ever. Shifts smoother than my pickup truck too.
Old 04-06-2015, 02:33 PM   #18
Somewhereintheusa laid it out pretty clearly.
1995 was the changeover year for most school buses and electronics.
Starting in 1996 the E engines started to show up.
About the same time the Allison World Transmissions started to show up as well.
By the time a school bus gets to the point where it is sold or traded in most of the bugs will have been worked out of the electronics except for that one garage queen that no one can get to run correctly.
In my experience I would look at either type without any reservations.
One caveat would be if you intend to run on WVO or bio-blends of more than 10%. Most of the "E" engines do not like anything except for 100% dino #2 or 100% dino #1 in the winter. Anything more than 10% bio-blends can be a problem for them.
I drove one of the many buses that was involved with the mess in LA, AR, and TX after Katrina and Rita. The older buses that had 2-cycle Detroit Diesels didn't care what sort of fuel we burned. All of the newer electronically controlled 4-cycle diesels really did not like the milspec fuel we had to use. It was more like Jet A or Kerosene and the "E" engines really didn't like it.
It gets back to what I have always said about purchasing a bus, there is no perfect bus out there. You need to find that one bus that meets most of your needs at a price that you can update or change what you don't like at an affordable price.
I have come across so very oddly spe'c'ed buses over the years. Not too long ago I was in a 40' Thomas Saf-T-Liner RE with a Cat 3126 250 HP engine that hit the redline at 61 MPH. I am sure that if you could have gotten into the transmission programming and released the 6th gear you would have then have been able to cruise very nicely at highway speed.
But if it had been an older bus with a Cat 3208 and MT643 you would have been stuck with a top speed of 61 MPH with only one real alternative to up the highway speed. And that would have been to swap out the rear gears for some more highway friendly gearing.
Everything in buses is a trade off. If you understand what use a particular bus was purchased to do you can then better understand the way in which the bus was spe'c'ed.
Old 05-07-2015, 11:38 AM   #19
Thank you for the wisdom Cowlitz
I think I found a couple great prospects for buses, but now I am stuck, I am new to New York area and have no idea where to take this thing.
I need to find some sort of yard within 45 minutes of Brooklyn that I can park it/work on it. Hopefully its at somewhere that can help me convert it. I really have no idea where to start. I am also super nervous about bringing it into the city with all the tight corners. Also I dont have the commercial license so I need to get it registered as an RV before I can drive it myself.
Does ANYONE know ANYONE that might have somewhere to take my bus to get it converted. I am open to paying and helping work on it, just need the right "partner" to work on it with that has a space to park it and the tools needed to custom fab some metalwork and woodwork needed to finish it out and in the NYC area so I could commute out there often enough to help work on it.
Old 05-07-2015, 12:05 PM   #20
Chassis: Saf-T-Liner
Engine: RE Cummins 5.9
I found a place via Craigslist. Was under storage I think. Best going with independent owners of lots Imo, less questions.
Kathos7 is offline   Reply With Quote
