Old 05-31-2016, 07:09 PM   #21
Coachwork: IC
Chassis: CE300
Rated Cap: 32
I've heard of extremely low gears in school buses. It all depends on the routes it was ordered for.
Roll Your Own Build Thread
Old 05-31-2016, 07:55 PM   #22
you want numerically Lower which leads to Less driveshaft revolutions per wheel revolution.. I never realized they put that high of gears on an O/D transmission bus..
are you sure it actually shifted to 5th and hit the Lock up?
I wouldve expected 4.78's or 5.31's in a school bus...
Yeah, I'm just sleep deprived so I'm not connecting my thoughts properly.
At 40mph I manually shifted it down to fourth to make sure it went back to fifth when I let it go back to full auto. From what I can find on the web, that is indeed an available gear ratio which as eastcoastcb says is all about what type of route the bus was originally spec'd for. I don't want to sink more money into regearing than I'm spending for the bus. So sounds like I need to go back to shopping again.
jake_blue is offline   Reply With Quote
