Old 04-09-2008, 10:02 AM   #1
Rear End Flakes
I'm looking at another school bus instead of fixing the one I got. I talked to the mechanic and he said that the motor and tranny are good but the last time they serviced the rear end there were some sizable flakes. Anyone ever rebuilt the rear end themselves or knows how difficult it is?
dlor1 is offline   Reply With Quote
Old 04-09-2008, 03:13 PM   #2
oldog12's Avatar
Re: Rear End Flakes
I would prefer to just swap out rear ends than to go and try to rebuild one of those suckers... Basically you have to take the whole freaking axle apart... Then you have to deal with the heavy gooey messy parts, and the pinion gears, I think, need to be pressed off and on.... Naaaa... Swapping out the axle would be the way to go if I were you, thank God I'm not
oldog12 is offline   Reply With Quote
Old 04-09-2008, 07:30 PM   #3
oldog12's Avatar
Re: Rear End Flakes
The more I thought about it.... What has caused the flakes?... Hmmmmmmm.... The gears would seem not to be meshing well, the gears are scraping the inner casing, or..... SABOTAGE!!!!
I still think swapping out the axle is the way to go......
Old 04-10-2008, 06:23 PM   #4
Re: Rear End Flakes
Yeah still sounds a bit tricky without a shop. Even if I could jack it up I don't think my dirt/mud driveway will support it.
Old 04-12-2008, 10:08 PM   #5
Elliot Naess's Avatar
Engine: 5,9 Cummins
Re: Rear End Flakes
It is rare that the entire axle housing assembly needs to be replaced. Most likely, what you would do is replace or rebuild the "pumpkin" -- the hogs-head shaped unit that the drive shaft attaches to the nose of. Strictly mechanically speaking, it isn't all that difficult to take the pumpkin out and in, but the darn thing weighs a... hmmm... well, maybe not a ton but darned close! And there is no flat bottom on it to place a common floor jack -- it would tip over and take some body-part off you for sure. A commercial gear and driveline shop would have the tools and know-how for handling the beast.
Who has kept their rear heaters? M1031 Conversion General Discussions 12 02-20-2022 09:45 PM
Looking for a new rear end phillbus914 Classifieds | Buy, Sell, Swap 6 12-12-2019 04:22 AM
Big Rig Rear End... NewSkewlHauler Conversion General Discussions 11 04-01-2009 03:25 PM
just got new rear end 5.57? adamanderr Conversion General Discussions 3 04-07-2008 10:52 AM
Rear storage / Rear door ideas allanwcoty Conversion General Discussions 0 05-17-2005 11:52 AM
