Old 07-12-2019, 12:37 PM   #1
Rear heater shutoff valve
Hey there,
Do any of you know if these are the valves to shutoff flow to the rear heater?
Bananjer is offline   Reply With Quote
Old 07-12-2019, 01:20 PM   #2
CMORGANSKOOL's Avatar
Coachwork: IC
Chassis: FE Bus
Engine: DT-466 7.6L Turbo Diesel
I don't know if it's a factory option. Mine has a valve that looks like an outside spigot that you can turn to close for the rear and one for the front heater. It's pretty easy to cut and install one.
CMORGANSKOOL is offline   Reply With Quote
Old 07-12-2019, 02:36 PM   #3
I was wondering if the ones in the pictures are the cutoffs. I added a better picture. Thanks
Old 07-12-2019, 02:47 PM   #4
Ciscokid's Avatar
Coachwork: Me
Chassis: 2001 IC
If you follow your water lines back from your external pump to feed your back heater it will lead you to the valve
Ciscokid is offline   Reply With Quote
Old 07-12-2019, 04:54 PM   #5
Coachwork: IC
Chassis: FE Bus
Just don’t turn them off and overheat your bus. You have to loop the line in most cases because the heat loop is a return line for the coolant.
Old 07-12-2019, 05:09 PM   #6
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Having them closed will not make the engine overheat. The loop is only needed if you want any of the original heaters/defroster to operate.
Those valves may be for the rear heater or may shut off all of the heaters.
heater
