Old 08-03-2016, 02:07 PM   #1
Recapped tires
So I've come to learn that all four of my rear tires are recaps. They look to be in excellent shape. Can I drive on these for a year or two before replacing?
bread519 is offline   Reply With Quote
Old 08-03-2016, 02:30 PM   #2
2kool4skool's Avatar
IMO caps are Russian Roulette. YMMV.
Don, Mary and Spooky the cat.
Old 08-03-2016, 02:46 PM   #3
Retreads on the rear are usually not an issue. As "used" tries, the sidewalls are likely to age out before you lose or wear the treads. Just monitor the tires closely, especially in your pre-trip checks. You should be just fine. I would start sacking some cash away for the inevitable tire replacement though.
BusFiend is offline   Reply With Quote
Old 08-03-2016, 03:02 PM   #4
I agree with BF...recaps are used by the millions on heavy commercial trucks, but ONLY on the rear. Never as steer tires. In fact, DOT prohibits their use on the front.
See items "d." & "e.". Good rules to go by.
https://www.fmcsa.dot.gov/regulation...section/393.75
Old 08-03-2016, 03:32 PM   #5
Awesome good to hear. They look to be brand new condition basically.
Old 08-03-2016, 04:42 PM   #6
thing I don't like about recaps, is when the come apart they can do thousands of dollars worth of damage, taking out holding tanks, wire, plumbing pipes, etc.
Old 08-03-2016, 04:53 PM   #7
Carry a "tire thumper" and use it regularly. If a tread is just beginning to separate...you will hear/feel it. Also used to check tire pressure equality. Comes in mighty handy in bar fights too.
Old 08-03-2016, 07:29 PM   #8
Chassis: IH
"Virgin" tires can do this too. A tire's main enemy is heat. Tires are designed to be able to carry a certain amount of load at certain pressures safely. Underinflation causes the tires to flex, and in turn, build up heat. Too much flexing will cause the tires to overheat, up to the point of melting the rubber inside the sidewalls and causing a blowout. This is true no matter if it's a virgin tire or recap.
Recaps can separate, but if it's properly inflated and not overloaded, this is pretty rare. The DOT would prohibit them if they were too unsafe.
Those items some call "tire thumpers", I call "Panhandler Malfunction Adjusters".
Old 08-04-2016, 04:21 AM   #9
Recapped/retreaded on the steer will be annoying to drive. Makes the thing handle like a barge, because the sidewalls are already a tread life old.
I recently changed the caps for clean skins on mine and it's night v day different, it goes where it's pointed.
You won't notice the lack of tire wall stiffness on the duals though. Most of the fuel saving tires are designed around soft sidewalls to reduce rolling resistance. So the urgency isn't there to worry about.
I'd suggest saving up and putting the rubber you want on your bus, retreads on the steer need to go, rears you can just wait till you've worn them out.
retiredChemist is offline   Reply With Quote
Old 08-04-2016, 09:25 AM   #10
Rated Cap: Your mom +1
As mentioned before this is a HUGE no no if you ever get stopped by the DOT guys... Recaps on steer tires are NOT LEGAL in any state per DOT guidelines not to mention extremely unsafe.
