Old 07-11-2017, 05:20 PM   #1
Engine: 5.9 cummins
Registering bus to rv
Ok I'm new to this I just bought a B600 shorty bus what is the easiest way to register it as a rv tag office in volusia co FL said I had to have the electric or plumbing or lp gas installed and certified by a rv builder
I doing all the work myself it will have a shower with portable potty, D.C. Power, and outside kit basically a grill with tank
Also I have found I might need to step up to a bigger bus running out of design room
Does anyone have advice on this
Thanks ynot
Ynot76 is offline   Reply With Quote
Old 07-11-2017, 05:27 PM   #2
I cannot speak to the process in Florida but if you exhaust options in Florida you may consider a work around.
You may be able to title & register it as a motor home in Vermont. You can do it by mail. There is a long thread on the subject.
When you are approaching time to renew take your VT paperwork that shows it as a motor home to Florida licensing and tell the that you brought your RV from VT and need to title & register in Florida.
You will be approaching FL with a rig allready registered as a motor home.
Hopefully this will not be necessary. Lets see what the Florida contingent has to say.
Good luck!!
