Old 05-24-2007, 11:22 PM   #1
oldog12's Avatar
Removing Rivets
Here's an interesting approach to remove all those freakin rivets:
http://www.globalair.com/discussions/ac ... ~/msgID=26
oldog12 is offline   Reply With Quote
Old 05-24-2007, 11:44 PM   #2
eggman's Avatar
Those rivet shavers are nice pieces of equipment. I have used one for many years. Unfortunately, some folks wont be able to set them correctly and leave a 3/8 or 7/16 diameter hole where a 3/16 hole should be. Also, if there is a gap between the structure and the skin, you will still dimple the back side out when knocking the backside of the rivet out. IMHO, I would drill the rivet out centering on the head then cleaning the hole up as you drill through. No dimplin on the material unless it was already dimpled during installation.
My $.02
Jeff
95 IH 72 passenger transit school bus w/ DT466 and 545 Allison.
79 IH Scout II/392 (0.030 over) Hamilton Injected/727/D300/Full size axles/36" Swampers/Lockers/OBA/38 gal Custom fuel tank, roll bar, tube doors.
eggman is offline   Reply With Quote
Old 05-25-2007, 03:00 AM   #3
oldog12's Avatar
Well, I just bought one of those shavers off of eBay for $88.00... I'll see if the investment was worth it.....
Old 05-25-2007, 10:45 AM   #4
lapeer20m's Avatar
though it was not real fun, i didn't think that grinding the rivet heads off with an angle grinder was all that bad. yo udo have to be careful not to damage the skin though.
Newly Purchased Skoolie - Tips for removing rivets and floor Alexlorraine01 Conversion General Discussions 7 07-01-2016 09:25 PM
Removing internal rivets timbrass Conversion General Discussions 11 07-01-2015 08:15 PM
Rivets Zephod_beeblebrox2 Conversion General Discussions 4 10-15-2014 11:36 AM
Removing rivets from rubrails jkindt Conversion General Discussions 7 03-07-2010 01:00 PM
Rivets! newbusser Conversion General Discussions 4 05-01-2009 12:49 AM
