Old 06-17-2019, 08:48 AM   #1
Chassis: Carpenter SB 2508
Engine: Navistar DTA360 disel inline 6 cyl, 5.9L
Reusing ceiling panel query
Quick question ... I'm considering reusing some of a metal ceiling panel to patch the emergency hatch hole. Anyone else done this? Any recommendations / guidance?
I plan to cut a hole in the patch to install an AC unit, and will build a support frame on the interior ceiling for the unit.
Thanks!!
Kaklehr is offline   Reply With Quote
Old 06-17-2019, 09:01 AM   #2
HazMatt's Avatar
Chassis: IH 3800, 8 window
I was concerned about using the thinner ceiling metal on the roof, being worried of the A/C's weight bowing it in.
Plus, it's periodic incontinence aside, I like having it there! Propped open for airflow & heat dissipation, I have designed a collapsible ladder for roof access thru it.
I went 2 segments back, cutting a hole with a reciprocating saw the precise size called for by Dometic. It seals well; never a leak, altho that thicker skin still does bow in a little from the weight.
iMi dos centavos!
Old 06-17-2019, 10:16 AM   #3
Ninjakitty's Avatar
Engine: 6.6 New Holland Diesel
Rated Cap: 60 kids, 10 window
It should work fine. Just frame it up nice and sturdy.
Nick
Old 06-17-2019, 11:08 AM   #4
Thanks!!
I used some ceiling panels I'd taken down to patch some roof stuff. Its thin but it'll work.
Roll Your Own Build Thread
ceiling, metal patch, reuse metal, roof patch
