Old 08-31-2019, 06:21 PM   #1
Rivets?
Hey Everyone,
I just got a voicemail asking questions about rivets. The message was unintelligible. All i understood was "skoolie" and "rivets".
I am not sure who messaged me but I will say that questions are better answered in the open forums rather than PM or voicemail.
Old 08-31-2019, 06:27 PM   #2
Hey Everyone,
How does anybody here know your phone number?
Old 08-31-2019, 06:31 PM   #3
brokedown's Avatar
Pretty sure he's posted it somewhere, but it could also be a stalker. Steve do you have a stalker?
Old 08-31-2019, 07:31 PM   #4
Rivetboy's Avatar
Hey Everyone,
Not me
Rivetboy is offline   Reply With Quote
Old 09-01-2019, 03:17 AM   #5
Maybe ithe voicemail was supposed to be for you, Rivetman1
Old 09-01-2019, 05:22 AM   #6
I think I can solve the mystery.
Its a Belgian man. His name is Wim. I've been busy but he called me frantically about rivets in the middle of my storm prepping.
He's really nice but stressed about grip range, rivet length, etc.
Old 09-01-2019, 08:23 AM   #7
brokedown's Avatar
That just made the story even more weird
Old 09-01-2019, 08:49 AM   #8
That went well with my second cup of coffee this morning...
But hey -- there's easily accessible legit info out there to share...
https://www.flight-mechanic.com/airc...ts-part-three/
https://www.fastenermart.com/underst...nd-rivets.html
saved the best for last!
http://www.cherryaerospace.com/docs/...gs/CA-1015.pdf
Old 09-01-2019, 12:32 PM   #9
Several
Old 09-01-2019, 12:35 PM   #10
I have exchanged phone calls with a number of members here as well as skoolie fans outside of the forum.
Old 09-01-2019, 12:38 PM   #11
I posted a link and contact info for the folks I bought my rivets from in my build thread.
The gent I spoke with was very knowledgeable and even knew a fair bit about buses. He helped me with selection of proper size, style and grip range.
Old 09-01-2019, 03:06 PM   #12
Jolly Roger bus 223's Avatar
Year: 86
Chassis: Ford B700
Engine: 8.2
hope you fair well charlie i am in prep mode also cause it looks like it gonna make a hard right and head my way.
I just got my house back together from last september
good luck to yall ECCB
Old 09-01-2019, 07:53 PM   #13
IIRC I gave it to him since his bus was out there in Oregon when he got it.
Old 09-01-2019, 08:22 PM   #14
BusT's Avatar
Engine: Dt466e
Rated Cap: 30,000
Cb good luck man with the storm man ! It lookin Gnarly!
I have a question about rivets !
International bus 2002
I’m drilling them out with a number 8 or 10 bit.
Not sure I get them from work. But usually what size should I go with or what’s usually manufacture sized rivets.
I want to to order some solid pop rivets ... or the self closing ones and also some buck rivets .
I need a bit too.
So say I’m going through 2 pieces of 14 gauge hat channel.
And old 16 garage sheet and my new 16 gauge sheet?
What grip range shall I need ?
If I bored a hole out too big should I go with 5/16 instead of 1/4 ... I think that’s standered ?
I need to make a order here pretty soon
BusT is offline   Reply With Quote
Old 09-01-2019, 09:16 PM   #15
I need a bit too.
Instead of having 2 different size rivets, use a backer washer or the head off another rivet on the back side,
Old 09-01-2019, 09:51 PM   #16
I need a bit too.
see post #8...
Old 09-11-2019, 10:58 PM   #17
I need a bit too.
Re 'POP' Rivets on a skoolie
Specified 2 thicknesses of each Gauge 14 and 15 sheet steel.
14 gauge = 0.078125" x 2 = 0.15625"
16 gauge = 0.0625" x 2 = 0.125"
Total thickness = 0.28125" = 9/32"
Grip Range needs to include the above figure for example, a 3/16 rivet with a 1/4 to 3/8 and have a rivet length around 1/2". The drill size will be a number 11 and will probably specified by the rivet supplier
Material of the rivet and it's mandrel should both be steel (not stainless steel) and if exposed to weather should have a closed end. Different manufacturers have different names for closed end rivets. Two names I've come across are 'domed' and 'protruding head'. Buyer beware.
boilerguy666 is offline   Reply With Quote
Old 09-11-2019, 11:13 PM   #18
I bought a bunch of 1/4" rivets and the manufacturer specified F bits which are nominally 0.257". The rivets turned out to measure about 0.26", rendering my package of F bits kind of useless.
Old 09-12-2019, 01:20 AM   #19
Sounds like they really F'd it up!
Old 09-12-2019, 01:22 AM   #20
On the bright side, you now have some nice new shiny F bits.
