Old 04-29-2017, 05:48 PM   #1
Coachwork: 34 foot blue bird
Engine: CUMMINS 5. 9
roadside assistance - towing
I am looking for a plan and company that takes care of there customer's when you need help.
OUT IN AMERICA is offline   Reply With Quote
Old 04-29-2017, 06:46 PM   #2
2kool4skool's Avatar
https://coach-net.com/
Don, Mary and Spooky the cat.
Old 04-29-2017, 09:57 PM   #3
roach711's Avatar
Rated Cap: 19
I have Good Sam Roadside Assistance for $80 a year. It covers your RV and cars too. So far I've used it to tow my cars but (fingers crossed) not the bus yet.
The Roach Motel
Old 04-30-2017, 07:23 AM   #4
BowserJournal's Avatar
Chassis: Ford B600
Rated Cap: 20 person
Does good Sam cover buses as well?
"Living Our Own Story"
The Bowser Journal
Watch our adventures by subscribing...
Youtube - bit.ly/TheBowserJournal
BowserJournal is offline   Reply With Quote
Old 04-30-2017, 08:12 AM   #5
Dog Rescuer's Avatar
They do cover Buses / Skoolies.
Dog Rescuer is offline   Reply With Quote
Old 04-30-2017, 09:11 AM   #6
Chassis: Ford B600
Sweet! We will have to Chang over from AAA
The Bowser Journal
Old 04-30-2017, 09:50 AM   #7
Ask them directly if they will cover stoolies...Some don't cover any buses, some not skoolies.
Old 04-30-2017, 12:05 PM   #8
Rated Cap: 37,400 lbs GVWR
I have Good Sam, and when I renewed by phone yesterday I was specifically asked to reconfirm the details of my "Crown bus conversion". So yes, they do cover bus conversions - however, maybe it would be better to not mention the words "school bus" or "skoolie" at all, merely referring to it like I do as a "bus conversion" to avoid any possible misunderstandings. A few months ago I had Good Sam tow my bus when its brand-new hydraulic fan motor for the radiator split apart after only 6 miles, effectively stranding me dead because I then had no cooling. It took a few hours before a suitable tow truck arrived (a shiny new half-million-dollar Kenworth 4-axle wrecker with all the bells and whistles), and another hour or so to remove the right-side axle shaft and connect air to release the brakes, but overall Good Sam did what they said they would. No complaints.
Good Sam has also taken care of my car when its fuel pump died without warning, so they are good for not only buses and RVs. I also like that they provide coverage in Mexico, potentially useful when I pick up folk from Tijuana airport - I don't plan on driving in Mexico otherwise because the bus services there are so good (WAY better than anything in this country), making it much easier to just take a bus wherever I need to go.
Old 04-30-2017, 12:40 PM   #9
Rameses's Avatar
Why did you have to pull an axle shaft to tow it?
Rameses is offline   Reply With Quote
Old 04-30-2017, 01:06 PM   #10
Chassis: IH
This is done to prevent transmission damage. Typically the driveshaft is pulled, but if the driveshaft is difficult to get to, then an axle shaft is pulled (pretty common when towing buses and larger RV's).
Old 04-30-2017, 01:08 PM   #11
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
So the driveshaft doesn't turn. Standard procedure in trucks.
Old 04-30-2017, 04:18 PM   #12
It's a lot easier to burp off the eight nuts and pull the shaft, even if you have to whack the flange with a BFH until it loosens! Getting the eight split cones loose was still a PITA. After the bus was towed back I used one of the new axle gaskets I bought from Ryder, tightened the eight nuts back to 150 ft/lbs as per my Rockwell manual, and filled the diff with a quart of 85W/140 hypoid gear oil to refill the right hub bearings. Actually the hardest part was jacking up first the left side and then the right side to flow the oil all the way through the axle tubes - hand-jacking a bus up a foot or so is bloody hard work! All's good now - I took the bus out for its first real test-drive yesterday after getting everything buttoned back together, and after a few good pulls through Santiago Canyon's hills I think it's good to go. Yeah!
Old 04-30-2017, 09:17 PM   #13
Rameses's Avatar
Personally, I don't think I'd ever go that route. I'd much rather pull two u-joint caps and tie the shaft up, rather than screw with gear oil and silicone. Even if it means sliding around on my back under a bus for 10 minutes.
Or better yet, don't do either. Pick up the back end, tie the steering wheel off, and drag it down the road backwards.
