Old 09-11-2019, 07:57 PM   #21
Chassis: Ford B700
Engine: 5.9L Cumins
Roof hatches
How about using a Bomar hatch. They are generally have a smoked plexiglass opening hatch. They come in all sorts of sizes.
NomadderFL is offline   Reply With Quote
Old 05-17-2020, 12:22 PM   #22
Great pictures. I am in the process of doing this myself. One question, to lay the sheet metal over the hole I see you lined it up close to the second row of rivets. What did you do with the row that your covering? Did you grind those out so the panel would sit flush? Thanks for the help.
Onlyfordguy is offline   Reply With Quote
Old 05-17-2020, 12:25 PM   #23
on that particular bus I ground the first row down a bit so it would sit a bit more flush then riveted it between the two factory rows.
I'll be doing my Thomas roof hatch, strobe, and passive vent delete in the next week or two and will update with some pics.
Old 04-08-2022, 11:49 AM   #24
That looks awesome what did you do for the inside?
Jeh1295 is offline   Reply With Quote
