05-13-2017, 06:09 PM
Chassis: HDX
Engine: Cat C7
Rated Cap: 84 passenger
Roof Hatches
How do I disable the roof hatch alarm function? Will cutting the cables at the hatch result in an open circuit that will set off the alarm? I'd like to be able to fully open the hatches if the weather permits. That, and it would allow me to get up on the roof for a possible patio.
05-13-2017, 06:42 PM
Cut the wires test the switch with an ohm meter when hatch is closed. If reading meter as 0 ohms when hatch is closed then connect wires together. If reading as an open circuit then cap the wires. Hope this helps.
Gordon
05-13-2017, 07:02 PM
You can turn the latch on the top hatch and pop it open. You'll have to put the latch back together well before you'll be able to start up again.
The hatch hinges nicely out of the way. Just pretend it's a fire drill.
Robin
Nobody's Business
05-14-2017, 04:53 PM
Chassis: HDX
Engine: Cat C7
I know about turning the red latch; however, the alarm going off will not add to the mood.
05-14-2017, 05:51 PM
If you look in my shorty thread it shows taking out the hatch and disabling the buzzer.
I just had to disconnect this wire
05-14-2017, 07:25 PM
The alarm shouldn't be going off unless you've got the key turned on. Mine doesn't buzz at all to just open it while the key is off, for roof access apparently. Maybe mine's different. They all seem to be a little different.
The other day the interlock apparently caused someone's electric fuel valve to stay closed, but it allowed them to crank the vehicle while the buzzer was going off. No smoke. Someone else removed their stop sign and the interlock engaged.
It seems that buses are like a box of chocolates? Everyone's interlock seems to disable a little different, even on seemingly similar buses. I'm too far out in the boonies to take a chance on activating the interlock and being stuck, especially with my adverse electrical abilities.
All I'm saying is you can work around the interlock, usually anyway. My latch reattached easily and I had no problems starting afterwards.
Robin
Nobody's Business
05-15-2017, 07:14 AM
I don't understand why ...
I've disconnected (i did not cut) my hatches, emergency Windows and stop signs and the alarm buzzer doesn't go off when I turn the key and start it up....
Should I just not look a gift horse in the mouth?
05-15-2017, 07:25 AM
If your windows, hatches, etc had four wires going to them, then they'd have had the interlock. My 92 and 98 AmTrans only had two to each, which made me glad.
05-15-2017, 04:03 PM
Chassis: International 3000RE
Engine: T444E/AT545
Rated Cap: 75
Ditto with mine. And the rear and side exits were already disabled when I got it
05-16-2017, 01:10 PM
Nice!!!
05-16-2017, 01:11 PM
I'm totally psyched!
05-16-2017, 01:16 PM
Hey, I wonder if you're anywhere near me...I'm in Westtown NY near New Milford NJ.
05-16-2017, 06:04 PM
That's all I had so I guess I lucked out [emoji2]
05-16-2017, 06:23 PM
Chassis: HDX
Engine: Cat C7
My E-door had it. I simply had to cut the wire and remove the switch. I haven't tried any of the E-windows, but the roof hatches are definitely armed.
05-16-2017, 07:17 PM
Both of my E doors only had the one wire along with both E Windows. I'm really lucky because I really have NO clue whatsoever about electronics.
05-16-2017, 07:41 PM
Me either, but I AM learning.
05-16-2017, 07:46 PM
AMOF I'm actually trying to learn it right now online. At least the basics. I'm not real bad at being self taught though, so let's see what I can do
