Old 03-29-2017, 11:55 AM   #1
Chassis: Genesis
Post Roof hatches: substitutes and replacements
Anyone know of an affordable replacement or sturdy substitute for old roof hatches?
We have a 1996 International AmTran with Specialty Mfg hatches, all cracked to hell.
SashaRosen is offline   Reply With Quote
Old 03-29-2017, 12:09 PM   #2
Njsurf73's Avatar
Chassis: Bluebird
Engine: 5.9 Cummins 24v
Rated Cap: 72 pax
Lots of people put vents in or just skin over the opening. Somewhere on this forum is a thread with some contacts for bus graveyards/salvage that may be able to help if you are looking to keep them functional.. although by all accounts they pretty much leaked from the factory lol
Old 03-29-2017, 01:02 PM   #3
Chassis: Genesis
Thanks for the heads up, now just to find that thread. The "search" function seems to be disabled on my mobile browser.
Old 03-29-2017, 01:45 PM   #4
I've got one you can have. Leaks like new!
Old 03-29-2017, 02:19 PM   #5
brokedown's Avatar
I <3 my roof hatch. It doesn't leak (yet)! If it ever stops working I will be a Sad Panda.
Old 03-29-2017, 02:34 PM   #6
Brewerbob's Avatar
Anyone use these?
Old 03-29-2017, 02:52 PM   #7
Engine: Navistar 7.6L
I bet we have a few Navy vets here that have.
DoubleO7 is offline   Reply With Quote
Old 03-29-2017, 03:04 PM   #8
Chassis: Genesis
Thanks EastCoastCB! That would be great! Im in Chicago though, how much is it to ship one of them?
Old 03-29-2017, 03:04 PM   #9
Chassis: Genesis
Originally Posted by Brewerbob View Post
Anyone use these?
This would make a great sidedoor!
Old 03-29-2017, 03:15 PM   #10
Chassis: MVP
Engine: CAT 3116
14 Gauge galvanized sheet metal, works wonders, haven't had a single leak since i replaced my hatches. I loved the hatches, but every school bus driver I spoke to said they pretty much leaked from factory...
Piersg is offline   Reply With Quote
Old 03-29-2017, 03:20 PM   #11
I had a couple 14ga squares cut out, but man that's THICK. that's what the ribs are made of! how'd you attach it?
Old 03-29-2017, 03:32 PM   #12
brokedown's Avatar
Gravity! Not just a good idea, it's the law!
Old 03-29-2017, 09:08 PM   #13
sojourner's Avatar
Engine: DT408
I'm planning on fabricating a new set from either steel or aluminum. I need to be able to stand up through mine to adjust the solar panel frame.
I am an sojourner in the earth; hide not Your Commandments from me. Psalm 119:19
Here is the patience of the saints; here are the ones keeping the commandments of YAHWEH, and the faith of Yahshua. Rev. 14:12
sojourner is offline   Reply With Quote
Old 03-29-2017, 09:09 PM   #14
sojourner's Avatar
Engine: DT408
Old 03-29-2017, 09:54 PM   #15
miltruckman's Avatar
Chassis: TC 2000 bluebird
Engine: 5.9 cummins
I used a Lewmar series 70 sea hatch. It was the correct size but I had to band saw some curved boards to make a flat surface to mount it on. The only problem is the price was pretty steep. I have yet to mount the "Ocean Skyscreen" blind/screen underneath it. So many curves and angles!
miltruckman is offline   Reply With Quote
Old 04-01-2017, 04:54 PM   #16
Chassis: MVP
Engine: CAT 3116
You are right, i just double checked it. I used 14Ga for a floor patch and 16Ga for the roof patches. I used butyl rubber tape between the patch and the roof and then I predrilled pilot holes around the perimeter and used those metal roofing screws with an integrated rubber washer. Both these, but similar:
https://www.amazon.com/Metal-ROOFING...TVJ71F312Q2MHM
Old 04-02-2017, 03:31 PM   #17
I was wondering! lol
After I realized 14 was WAY too thick, I got a couple of 16ga squares cut out. Still haven't stuck em up there yet.
Old 08-22-2018, 05:29 AM   #18
Year: 2006
Coachwork: MID BUS INC Chevy
Chassis: YY
Engine: 3500 Dieisel Express v8
Rated Cap: 26
Hi Skoolies! Thanks for all the great tips. In the process of converting our Mid Bus after years of deciding what would be the best platform.
The roof needs paint before winter and I need to patch hole from leaky emergency hatch and install maxx fan. Question: 2006 metal up there seems thin and I can’t find a big enough peel of steel. I can find aluminum. Can ai patch and seal that up there or am I gonna have a reaction?
Ravendancer is offline   Reply With Quote
Old 08-22-2018, 07:33 AM   #19
AFAIK you'll have a reaction if it's bare metal to bare metal. As for me, when I skinned over the hatches (albeit with steel) and put in MaxxAir fans, I had so much butyl tape and sealer that there didn't seem to be a chance of metal contact between the 2 pieces of steel. The self-tapping sheet metal screws, however, is a different story......not sure how you'd get around corrosion there.
Old 08-22-2018, 12:53 PM   #20
Isn't steel cheaper than aluminum?
Just call a steel shop and tell them the size and thickness.
Don't buy it at a box store!
amtran, genesis, international, roof hatches
