Old 03-29-2017, 03:20 PM   #11
Originally Posted by Piersg View Post
14 Gauge galvanized sheet metal, works wonders, haven't had a single leak since i replaced my hatches. I loved the hatches, but every school bus driver I spoke to said they pretty much leaked from factory...
I had a couple 14ga squares cut out, but man that's THICK. that's what the ribs are made of! how'd you attach it?
Roll Your Own Build Thread
Old 03-29-2017, 03:32 PM   #12
brokedown's Avatar
Gravity! Not just a good idea, it's the law!
brokedown is online now   Reply With Quote
Old 03-29-2017, 09:08 PM   #13
sojourner's Avatar
Engine: DT408
I'm planning on fabricating a new set from either steel or aluminum. I need to be able to stand up through mine to adjust the solar panel frame.
I am an sojourner in the earth; hide not Your Commandments from me. Psalm 119:19
Here is the patience of the saints; here are the ones keeping the commandments of YAHWEH, and the faith of Yahshua. Rev. 14:12
sojourner is offline   Reply With Quote
Old 03-29-2017, 09:09 PM   #14
sojourner's Avatar
Engine: DT408
I've got one you can have. Leaks like new!
Old 03-29-2017, 09:54 PM   #15
Chassis: TC 2000 bluebird
Engine: 5.9 cummins
I used a Lewmar series 70 sea hatch. It was the correct size but I had to band saw some curved boards to make a flat surface to mount it on. The only problem is the price was pretty steep. I have yet to mount the "Ocean Skyscreen" blind/screen underneath it. So many curves and angles!
miltruckman is offline   Reply With Quote
Old 04-01-2017, 04:54 PM   #16
Chassis: MVP
Engine: CAT 3116
You are right, i just double checked it. I used 14Ga for a floor patch and 16Ga for the roof patches. I used butyl rubber tape between the patch and the roof and then I predrilled pilot holes around the perimeter and used those metal roofing screws with an integrated rubber washer. Both these, but similar:
https://www.amazon.com/Metal-ROOFING...TVJ71F312Q2MHM
Piersg is offline   Reply With Quote
Old 04-02-2017, 03:31 PM   #17
I was wondering! lol
After I realized 14 was WAY too thick, I got a couple of 16ga squares cut out. Still haven't stuck em up there yet.
Old 08-22-2018, 05:29 AM   #18
Year: 2006
Coachwork: MID BUS INC
Chassis: YY
Engine: 3500 Dieisel Express v8
Rated Cap: 26
Hi Skoolies! Thanks for all the great tips. In the process of converting our Mid Bus after years of deciding what would be the best platform.
The roof needs paint before winter and I need to patch hole from leaky emergency hatch and install maxx fan. Question: 2006 metal up there seems thin and I can’t find a big enough peel of steel. I can find aluminum. Can ai patch and seal that up there or am I gonna have a reaction?
Ravendancer is offline   Reply With Quote
Old 08-22-2018, 07:33 AM   #19
AFAIK you'll have a reaction if it's bare metal to bare metal. As for me, when I skinned over the hatches (albeit with steel) and put in MaxxAir fans, I had so much butyl tape and sealer that there didn't seem to be a chance of metal contact between the 2 pieces of steel. The self-tapping sheet metal screws, however, is a different story......not sure how you'd get around corrosion there.
Old 08-22-2018, 12:53 PM   #20
Isn't steel cheaper than aluminum?
Just call a steel shop and tell them the size and thickness.
Don't buy it at a box store!
amtran, genesis, international, roof hatches
