Old 01-14-2008, 11:45 AM   #1
frank-id's Avatar
Re: Roof Vents
There are many RV vents from the salvage RV places. Repair the roof with the same metal as used by the bus maker. Make the repair metal about 6 inches larger. Add interior bracing and add a 14 inch square vent. Light and fresh air are always welcome. Most roof AC units and vents are the same physical size.
The crank vents with no fan are about $30 new. When installing repair patch, use some caulking product between the sheet metal. It will be labor saving if the sheet metal was painted before the placement. Frank
While working on some roof vents frank-id Everything Else | General Skoolie Discussions 7 09-27-2012 04:56 PM
How did you guys install your roof vents ? RichardRWatson Conversion General Discussions 13 04-25-2010 10:58 PM
Solar roof vents... or regular? TygerCub Electrical, Charging and Solar 6 08-13-2009 05:44 PM
Driving with Roof Vents Open Ottomobile Conversion General Discussions 8 03-28-2007 07:49 PM
What's a good sealant for roof vents? KC10Chief Conversion General Discussions 0 03-26-2007 11:55 AM
