Old 06-18-2009, 09:27 PM   #1
Engine: 6.9 IDI diesel
S1600 more power
I have been fixing up my S1600 the last few weeks. When I had the air cleaner off I noticed it had a restrictor plate welded in the bottom of the air cleaner that reduced the surface area by about half. I drilled out the spot welds and removed it. When I took the truck out for a ride it had much more power. I just went from 8.25" x 20" tires to 11R22.5's and even with the higher gearing the truck can run up to the governor on inclines that had it choking before. Next up is to advance the pump timing and turn up the fuel a little and maybe a less restrictive muffler.
silentbob is offline   Reply With Quote
DC or AC power? Locutus Electrical, Charging and Solar 3 07-31-2010 07:44 PM
re: more power themissingparts Mechanical and Drivetrains 7 06-07-2010 06:08 PM
No power wmah Everything Else | General Skoolie Discussions 2 06-11-2008 03:39 PM
Power. I want more power! crazycal Conversion General Discussions 20 03-05-2007 05:23 PM
ATX PC Power Supply to a 12 Volt Power Source vonslatt Everything Else | General Skoolie Discussions 3 02-15-2006 06:57 PM
