01-30-2018, 01:23 PM
Screws and Rivits
While looking at pics and watching school bus conversion videos I see people removing rivits from walls and ceiling. All the interior in my bus is screwed together and seems as though it came that way. Do some come with screws instead of rivits?
Doesn’t make a difference to me just curious.
01-30-2018, 01:33 PM
Thomas buses used a lot of screws. I think when it gets down to removing/replacing 500 screws or 500 rivets, you'll wish to God they were screws.
01-30-2018, 01:50 PM
As he said. My Thomas was all screws on the inside. Screws are easier than rivets to be sure, that doesn't mean they are easy! Even with a good impact drill you're going to fatigue pretty fast working overhead.
My BlueBIrd is all rivets. I'll be starting that part this weekend....
Screws are easier to remove
01-30-2018, 02:00 PM
My 92 Ward had rivets. My 98 and 04 AmTran/IC's came with screws.
01-30-2018, 03:18 PM
I can’t wait to start on the gutting process. It needed a PMD and the injector return lines were leaking so I’ve been concentrating on the mechanical part o things.
01-30-2018, 03:20 PM
Definitely. Should be a breeze, I’ve been told more than once that I’ve got a few screws loose already
01-30-2018, 03:50 PM
Chassis: Saf-T-Liner MVP ER
All screws in my Thomas.
I bought a Porter Cable Impact Driver .... and a lot of Philips #2 impact bits.
There is a knack. Start the driver very slowly. Let it hammer the screw loose without the bit slipping, then hit the trigger harder.
In the entire interior removal I have had maybe 15 screws, out of many, many hundreds, that refused to budge. Of those maybe 12 succumbed to an angle-grinder slot and large screwdriver, and about three needed drilling or chiseling out.
Rivets would have taken a lot longer.
01-30-2018, 03:57 PM
If your screws are the same as in my Thomas, #2 was the wrong bit. #3 is the correct bit for mine and will pull them all out with no damage to screws or the driver bit.
01-30-2018, 04:34 PM
Most of mine are #2, #3 won't even go in.
In a few places they used larger screws, they are #3.
#3 will always slip much less, it has more meat to get hold of.
01-30-2018, 05:51 PM
Lol...lost most of my screws...damn it I don't need these nuts now....
01-30-2018, 06:08 PM
Year: 86
Chassis: Ford B700
Engine: 8.2
If you want to use the NUTS then you don't need to worry about the screws you lost?
But if your screwing everything it is probably cheaper to lose the nuts?
For most of my screws a #3 was to big and a #2 was a little small but only because the tip was a little to long for the number 2 to fully seat.
I quit going through bits after I cut a little bit of the tip off of the 2 and for the ones that still wanted to hang on a few whacks with an old screw driver and hammer hammer used like a center punch would brea them loose.
Wear protection when working with your tool.
01-30-2018, 06:12 PM
I think we're on the same page...if so...you out did me...
01-30-2018, 06:21 PM
Year: 86
Chassis: Ford B700
Engine: 8.2
I do try a little humor every now and then while at work.
Same page. Yeah I caught where you were going but was only trying to expand on your quote not out do you.
I saved all of my screws and have used most of them but some were to wore out and just didn't quite fit anymore.
01-30-2018, 07:53 PM
I can tell you with confidence that after about seventy years...screws turn into rivets. My entire bus body was screwed together. I think I managed to get about three out in one piece.
01-30-2018, 08:24 PM
Ditto what Tango said. My bus was also 100% screws--slotted screws, rusted screws but no Phllips screws. About half of them yielded just enough to rip the threads off the screw to become free spinning. I treated those like rivets and ground them off. Fortunately, once the heads were gone I was able to use a drift to punch the unthreaded screw shanks out. After running a 1/4" tap through the threaded holes in the body bows I was able to simply replace the screws when I re-installed the inside sheet metal.
My bus is done (except for the stuff that breaks and has to be repaired) and I never even think of how much work it took to complete the project--it is just way too much fun to use and enjoy it. Jack
01-30-2018, 08:30 PM
Yeah, but your bus is about 800 years old, right?
01-30-2018, 09:00 PM
I just looked at your build thread and WOW! Nice work. I love the look of the old buses, with the curves and angles they have a organic kinda look. Hand crafted, not spit out of a machine somewhere. Hope your a people person, your gonna have a line of folks asking about it every time you stop.
01-30-2018, 10:05 PM
Actually, that is a concern. I am more of a hermit than a socializer. Don't get me wrong...I like people...well, some people...but then, I am more inclined to spend time in remote, semi-desolate areas, so the crowd thing should not be an issue.
Coyotes and pumas welcome!
01-30-2018, 11:15 PM
Lol...I was enjoying the conversation but figured it was best to not continue down that slippery slope...
