08-27-2017, 09:07 PM
Shifting issues
Anybody know a good mechanic in Seattle/Tacoma area? Had some airlines blow, replaced them and holding psi but now the tranny doesn't shift right. It takes a good while to get out of first, will go into second then third but that's it. The rpms are staying low (no higher than 2200). I had no transmission issues before replacing airlines. Thomas MVP Safe-T-Liner MVP/CAT 3116 rear engine with Alison MT643
Sent from my LG-H918 using Tapatalk
08-28-2017, 02:08 PM
Change transmission filter and put c-4 rated hydraulic fluid had the same issue If it takes a long time to shift into reverse that's the problem
08-28-2017, 02:15 PM
if you have an air throttle theres a chance you have an air-operated modulator on that 643.. make sure if there is an air line going to modulator it has pressure based on the throttle and not full air all the time.
08-28-2017, 02:32 PM
I have had troubles with reverse. Thanks!
08-28-2017, 10:01 PM
Learned that the hard way spent 3 days in Laramie Wyoming on the net doing research and that's what I discovered if it's in a bus make dam sure you buy C-4 rated hydraulic fluid not ATF to light for the load you have the Allison 545 ?
08-28-2017, 10:02 PM
Allison 643
08-28-2017, 10:03 PM
Should have another filter near engine compartment it takes ex 5 gallons buy at Walmart
08-28-2017, 10:04 PM
Yeah, it does.
08-28-2017, 10:07 PM
Ok look it up should say anything C-4 rated off road they use C-4 rated 15w40 motor oil but don't do that ever since I changed the filter the next 1500 miles shifted smoothly that's after the Allison mechanic said my clutches were shot i disagreed and I was right saved $2800 on a rebuilt transmission
08-28-2017, 10:09 PM
You will find after running it the external filter will be cool not warm or hot lack of circulation!Filters
08-28-2017, 10:17 PM
Mine once left me dead in the water on a 6% grade till It cooled down next day is when it took a crap if you're able put two quarts of Lucas transmission cleaner can be got at truck stops let it clean up the hydraulics then change out filter and fluid if your not Able to drive around to work it thru the system then sit and change forward reverse quite a few times it's not necessary to add the cleaner but helps hydronic fluid has a lot of cleaning additives in it
08-28-2017, 10:20 PM
I can try that between Fwd & R, I'm not really in an area where I can drive at 10mph until she finally goes into second without being nuisance.
08-28-2017, 10:22 PM
I don't know anything about them air throttle that maybe his problem
08-28-2017, 10:25 PM
Then just change filter the best place to find them is Napa
08-28-2017, 10:27 PM
Yeah, that'll be what I try first thing in the AM.
08-29-2017, 04:39 AM
I was told by an Allison guy that a 545 being used in severe duty could run 15W40 engine oil, like rotella t4. He also said that it's suggested only to do that if a full flush is performed, 2 or 3 changes to get oldvfluid out or do it on a fresh rebuild transmission.
Yes to changing the outer spin on filter and the internal pan filter.
Christopher
