Old 10-30-2018, 11:54 PM   #1
Short skoolies MPG
I’m thinking about getting a short, mini, small bus but I’m having trouble finding MPG info on the short busses. For everyone that drives a mini Skoolie what’s your average mpg, what are your specs and your driving style? I want to be informed to the best of my ability before I jump in since I’m also considering getting a older van but if the fuel economy is about the same I’ll just get the bus. Thanks in advance.
ZyxPanda is offline   Reply With Quote
Old 10-31-2018, 03:15 AM   #2
The Type 'A' buses on the Chevy/GMC chassis with the 6.0L/6L80 or 6.0L/8L80 power package is about as good as it gets. Depending upon load and speed they will get 12-14 MPG with an honest 13 MPG average.
The Type 'A' buses on the Ford chassis with the V-10/E4OD (or later variant) will get 10-12 MPG with an honest 11 MPG average.
The Type 'A' buses on the Chevy/GMC chassis with the Duramax will climb hills faster than just about any bus but the fuel mileage isn't that much better. Figure on 13-15 MPG with an honest 14 MPG average.
The Type 'A' buses on the Ford chassis with the 6.0L diesel usually didn't go far enough to figure out fuel mileage. Unless the engine was bullet proofed it is a $5K-$10K repair waiting to happen. Fuel miles was in the 12-14 MPG range.
The Type 'A' buses on the Ford chassis with the 7.3L got 11-15 MPG depending on weight, speed, and shape of the bus. We always got 1-2 MPG better on our buses that were more aerodynamic than the brick shaped buses.
Type 'A' buses on the Ford chassis with the 460 gas V-8 got 5-9 MPG with the honest average closer to 5 MPG than to 9 MPG.
The Type 'A' buses on the Chevy/GMC chassis with the 6.2L diesel V-8 were underpowered, slow, noisy, and not very fuel efficient. 10-14 MPG. The engines were pretty stout but underpowered in a bus.
The Type 'A' buses on the Chevy/GMC chassis with the 6.5L turbo diesel V-8 were marginally better on fuel economy at 12-16 MPG with an honest 14 MPG in there somewhere. The power was better than the 6.2L but it was no barn burner. The new 6.0L gas V-8 has more power and torque than either the 6.2 or the 6.5. The downside with either the 6.2 or the 6.5 is GM stopped supporting any parts for the them some time ago and virtually nothing is available aftermarket because so few G-models came with the turbo diesel. There are some dealer only parts and pieces that do need replacing over time that are getting into unicorn status with prices to match.
Old 11-02-2018, 04:16 PM   #3
5.9 Cummins
I’ve found a 2002 freightliner diesel with a 5.9 cummins motor it’s a 7 windowed bus would the motor be to under powered?
diesel, mini bus, mpg, short
