09-11-2015, 02:17 AM
Engine: 190hp 5.9 Cummins
Skoolie built into a Boat
In a effort to be able to go places where no one else is and have amazing fishing, I'm thinking of building a bus into one of these.
I would remove the entire chassis, and just use the body. Floor would be removed from the chair rail down, and a new bottom built 6 inches wider on each side.
Cool idea, lots of work.
I would be after exploring the lakes here in northern Canada more than rivers. But being able to travel the rivers would take me to places beyond where the roads could.
09-11-2015, 03:31 AM
Hey Nat, have you considered leaving the floor and structure and seting it on to a framework using pontoons? 3 or 4 rows. I think that would be fun to build actually.
09-11-2015, 03:40 AM
Building a barge sitting on pontoons and driving the bus onto it is likely what I will do.
The barge will be a trailer, with a main deck, and two fold down sides to add width and stability / deck space.
The barge has advantages.
The bus can be built normally as I was for normal road travel.
Barge can be left at home when not heading to the lake.
If one pontoon gets a leak, the bus won't sink like the river boat.
It keeps the bus out of the water.
I can still use my really large belly storage just like I'm on land.
Ect.
My target weight calculation is 40,000 pounds. This is over kill, but when trying to float something, it's best to over calculate.
I have searched high and low for options. Everything from plastic floating dock sections to foam filled pontoons made for house boats. I even looked at using plastic rectangular water tanks.
Almost all are big $$$. Insane amounts of $$$.
Also I didn't like the size of the air chambers. If one gets a leak, I want redundancy for safety.
So for $20 each I can get blue plastic 55 gallon drums. Each one floats 450 pounds.
40,000 divided by 450 is around 100 drums.
Each drum is 24 inches in diameter, and 35 inches long. So to build a 45 foot long barge, you get 15 drums per row, and 4 rows per 8 feet of width.
That's 60 drums for the main deck of the barge. Each fold down side only needs 20 more drums each. Side will also be 8 feet wide to give a barge platform 24 feet wide by 45 feet long.
Drums weigh 22 pounds each. So that's 2200 pounds of plastic.
Structure for the barge would add another 2000 pounds.
Final weight for the barge should be around 4500 pounds.
That leaves 35,000 pounds for the bus to float.
Without any question, this would be more than stable enough to keep the bus from tipping / and stable on moderate waves.
Living on the water has all kinds of advantages. Like unlimited refrigeration in the cool northern water. A tank with a opening top would be my fridge.
I would use lake water directly from the lake. Waste water would only be grey. I would hold it for dumping on land and use only natural biodegradable soaps. No chemicals, same as I live now.
I can taste the fresh northern Canada fish already. Mmmm
09-11-2015, 04:37 AM
OH yeah! Even better. I like the way you think Nat.
09-13-2015, 04:10 PM
I've thought about the same thing. I came across this guys stuff a while ago. Looks like the original website is down, but googling "myark barge" brought us pics and various threads from other forums.
But depending on how long your bus is, the length of bus + trailer could get loooong. So I thought about integrating fold down pontoons like these have. (conversion starts at about 3:20) These wouldn't allow a roof raise though. Also, they might not be able to support all the weight of the bus. Plus that would be a TON of fabrication.
What I REALLY want is one of these. But those are custom made from the ground up and cost big money. To try and do something like that with a skoolie would certainly be even more fab work. If it would even be possible. Less headache to just buy a nice used boat/houseboat and trailer it to the water.
This is almost exactly what you described. Has all the benefits you outlined. (bus is built normal, use of belly storage, etc.) Look at all the vids from that last guys account. Has many short clips about all the advantages of using barrels and going the route you are thinking of.
09-14-2015, 07:35 PM
Great stuff.
Thx for adding to the thread.
09-14-2015, 07:50 PM
Chassis: B3800 Short bus
I've had similar ideas myself! We have plenty of Coast Guard construction rigs around here and I had a fleeting dream to buy an old barge and park the bus on it. I was thinking it'd be cool to be able to disconnect the drive shaft from the axle and drop it down to a shaft that connects to a propeller. The front wheels could rest in saddles that control a rudder. Slow, steady schoolie barge bus!
Add an ice bubbler to that and your good all year round.
09-14-2015, 08:16 PM
Chassis: Thomas
Engine: International Navistar DT360
Rated Cap: 60
I've been thinking of getting into something like this in the future as well. I'll be keeping an eye on your progress, whenever it happen!
My build thread:https://www.skoolie.net/forums/f11/build-thread-for-haulin-oats-and-goats-11237.html#post113500
A gal, a guy, three cats, two dogs, one rabbit, and one goat, traveling the country together.
09-16-2015, 09:48 PM
I may add a PTO output so I can connect to a propeller without having to disconnect the drive shaft. There is a whole bunch of things I would like to run off a good PTO.
The plastic barrels are tapered, making them rise when the ice freezes and expands. As long as I use enough so they are not floating to deep, with the water line passed the center of the barrels.
I just love the modular way this go's together.
This is likely the way I will build mine. Nice and simple, but without the upper deck. Upper deck will be on the bus roof.
09-17-2015, 12:12 AM
I mean other than, because I can, Why? A skoolie is just way to over built for a bus and heavy for what you want. you could take the top off and use the engine toss the floor frame and transmission. But Why? All it will end up being is a $3k pilot house.
09-17-2015, 10:09 AM
Chassis: Thomas
Rated Cap: 60
I think the idea is to still be able to drive the bus on land, right? I'd love to be able to barge around the Americas and drive up on land to adventure.
09-17-2015, 11:03 PM
You'll have to do a LOT of research on this train of thought. I've yet to see any clever designs that can accommodate Canadian fresh water ice. It's evil stuff. The effective designs usually employ serious rock cribbing + concrete. Ice grabs on to everything and - in big bodies of water with decent expansion/contraction - shreds man made structures to pieces. I see the damage every year: the dock that wasn't pulled in; the piers of boat houses... Ice is impressively destructive.
09-17-2015, 11:25 PM
I hear you on that. I grew up a few miles from a lake, and could hear the ice heaving miles away. It would push up 10 feet high ridges at the shoreline.
Every dock I have seen left in the water also gets destroyed. The hydraulic force of ice expanding is one of the most powerful forces of nature.
My thoughts are it needs to be out of the ice. As in on top of the ice.
Might have to climb out of the water to the land till she freezes, then head back out on the ice.
I would love to do a test this year, but live in a way to populated area to mess around in the water. I would called in for sure.
And I don't know anyone close with a dug out.
09-29-2015, 07:44 AM
Aquaduck tours Albany NY:
11-10-2015, 03:41 AM
Saw this and thought of this thread.
11-10-2015, 10:44 AM
Coachwork: Crown / Pusher
I notice they didn't show any other boats going by making a wake it had to bounce thru, or sliders.
