Old 12-22-2010, 11:20 PM   #1
lornaschinske's Avatar
Rated Cap: 89
Solar Window Inserts
I've been cruising this http://www.instructables.com site and they have a solar section. A lot of DIY solar panels and the like. The Solar Window inserts sounded promising for the bus conversions so I thought I would post a link....
http://www.instructables.com/id/Solar-Window-Inserts/
Fulltime since 2006
Old 12-23-2010, 10:40 AM   #2
Stuff's Avatar
Re: Solar Window Inserts
ID probably do that for my large dining room windows but I have them plastic'd off for the winter.
looks like its a wood frame, screened and then a solar heat absorbing material that builds up heat between it and your window then vents out the top?
can you post the pdf here? i dont really wanna sign up there. atleast yet.
Old 12-23-2010, 10:53 AM   #3
Rated Cap: 89
Neither do I! Too cheap. I "cut-&-paste" type & Pics into a Printmaster Newsletter. It's my lazy way of taking notes. I can still save the info in a PDF thru my Printmaster program. You just keep clicking on "next step" to get all the info. You don't HAVE to sign up. Signing up ($) means you can enlarge pics (so can I if I copy image into Printmaster) and get the info as a PDF. You should be able to do the same in OpenOffice.
It's one of those sites that gets you to thinking.... Lots of different subjects.... They also have FOOD!
Fulltime since 2006
Solar ovens and solar water heaters/showers tomas_maly Heating, Cooling and Appliances 6 05-22-2013 11:43 AM
SOLAR chev49 Conversion General Discussions 1 12-13-2012 11:07 AM
camper windows and bluebird rib inserts ramairws601 Classifieds | Buy, Sell, Swap 1 09-19-2010 07:21 PM
Solar?? KKGREENBIRD Conversion General Discussions 0 08-11-2010 12:02 AM
google ad inserts Steve Forum Admin | Account Help | Suggestion Box 3 03-04-2010 09:53 AM
