Old 03-26-2005, 04:19 PM   #1
captainkf's Avatar
Year: 1985
Engine: 366 propane
Rated Cap: 56
Spare Tire?
Does anyone carry a spare tire? I had planned on carrying one on our trip this summer. I know they are heavy, but I though if I had one then I could call the auto association and possibly have them swap them roadside, that is if I can't. Just wondering. It seemed like a good idea however I see no photo's of extra mounted tires on buses. -Richard
captainkf is offline   Reply With Quote
Old 03-26-2005, 04:55 PM   #2
lapeer20m's Avatar
when i took my big cross country trip last summer i brought a spare with me. I ended up getting a flat when i was about 2,500 miles from home, so it worked out quite well.
it's not too difficult to change them yourself if need be. If it's a rear duel, you can usually drive quite a long distance to a big truck tire shop and have them do it for you.
I put my spare tire inside the rear door of my bus. i have a bit of a storage area back there.
I do not keep my spare with me most times, however i don't generally venture more than 50 miles from home.
I've seen them mounted on top of a bus on the roof rack. I think that under the bus would be a fine place to keep the spare also. you were right when you said that they are heavy! It takes two people to get one of those tires (mounted to a rim) into the back door of the bus.
In the 20K plus miles i've driven on mostly worn out tires i've only had two flats, both were rear duals.
Old 03-26-2005, 11:45 PM   #3
AK-Brando's Avatar
My bus came with a spare tire in a compartment mounted under the left rear of the bus. I don't have any pictures of the compartment since the bus is "winterized" in Palmer, and I live in Valdez (aprox 250 miles away).
You can kind of see the door to the tire compartment behind the rear wheels in this picture: http://www.skoolie.net/gallery2/AK-Brando/Bus_2
This picture shows how the compartment is slanted to hold the tire: http://www.skoolie.net/gallery2/AK-Brando/Rear
And this is what the back of the bus looks like fully loaded with all our stuff:
http://www.skoolie.net/gallery2/AK-Brando/Loaded_back
I did have a flat with the bus fully loaded during our move to Valdez, you can read about it on my weblog here: http://home.gci.net/~graymouser/Bus/...in-valdez.html
Brian
'91 Thomas/Ford B700 7.8L Diesel 5-speed (seats removed)
My Bus Pics
My Bus Blog (hasn't been updated in a LONG time)
AK-Brando is offline   Reply With Quote
Old 03-27-2005, 09:08 PM   #4
Firearm's Avatar
Send a message via ICQ to Firearm Send a message via AIM to Firearm
Make sure to invest in a good jack or two and a weighted lug wrench or a good 12v electric impact wrench to break the nuts loose. You'll thank me later.
Firearm is offline   Reply With Quote
Old 03-27-2005, 10:34 PM   #5
captainkf's Avatar
Year: 1985
Engine: 366 propane
Rated Cap: 56
Tire
Thanks All. I plan on carrying a spare, but I have never seen a DC power impact. Can you recomend any and where? Thanks. -Richard
Old 03-28-2005, 12:48 AM   #6
Eric von Kleist's Avatar
Year: 1985
Coachwork: ThomasBuilt
Rated Cap: 60
Air changing
If you have air brakes, I have read that you can install a tap on the airline to run air tools from. An air wrench might be a option, too.
Eric von Kleist is offline   Reply With Quote
Old 03-28-2005, 01:21 AM   #7
AK-Brando's Avatar
Speaking of tools to remove the lugnuts... We had along a 6 1/2 foot breaker bar. Even with that it took about all my weight to break the nuts free!
Brian
My Bus Pics
Old 03-28-2005, 11:09 AM   #8
captainkf's Avatar
Year: 1985
Engine: 366 propane
Rated Cap: 56
spare tire
I do not have air breaks, but that sounds like an interesting option for those that do. So if I were putting together an emergency kit for a bus, what would it look like?
Spare on a rim
one or two 20 tonne jacks
wooden blocks (for jacks)
breaker bar (gas pipe) 6-7' long
lug and wrench
tow rope (just in case)
reflective triangles for use on road (late night breakdown)
basic tools
Jumpers
winter survival kit if appropriate
Auto card valid for RV's
What else do you all carry or would like to?
Just wondering. -Richard
Old 03-28-2005, 03:16 PM   #9
Firearm's Avatar
Here are some links for 12 volt impact wrenches. Another option is a cordless impact like we use at the racetrack.
http://sunlightcn.en.alibaba.com/offerd ... rench.html
http://www.dcimpact.com/page/page/784275.htm
The first one is like my brother-in-law's and it spins and builds up speed then engauges hard and "slams" the nut with pretty good force to break it loose. The second one uses an attached power supply. (Cool demo video on the dcimpact page too.) I use one that looks like a cordless drill but I don't know if it would have enough torque for a truck lug.
Old 03-29-2005, 10:07 AM   #10
Send a message via Yahoo to TravelingMan
I'd take a gallon of oil.
An extra fuel filter if you have a deisel. Had to change a couple of those because of bad fuel.
Extra headlight. Truck stops always charge premium.
Fuses and bulbs
If you have air breaks its always wise to have some way to splice air-lines so you can get it to the shop. They dont call that big chunk of tread in the middle the road a gator for nothing. It'll reach up and bite ya.
"I'm a man of means by no means King of the road"
TravelingMan is offline   Reply With Quote
christmas miracle denver spare 9.00 r 20 frank-id Classifieds | Buy, Sell, Swap 1 12-25-2010 10:45 AM
Spare tire mounting sdwarf36 Conversion General Discussions 1 07-19-2010 06:27 AM
Mounting Spare tire kirkndopp Conversion General Discussions 7 12-02-2009 01:19 AM
stupid spare fuel tank!!!!! C00LR Everything Else | General Skoolie Discussions 4 10-16-2009 05:46 PM
Spare tire Mounts Sidekick Conversion Tutorials and How-to's 15 08-18-2008 06:24 PM
