Old 07-05-2015, 01:06 AM   #21
Engine: 190hp 5.9 Cummins
Originally Posted by miltruckman View Post
I wonder if there is enough travel in those jacks to change a tire. Depends on how much the suspension moves. Mine are drop leg too. But then only have about 12-1/2" of lifting travel after the leg is down.
Bill
Mi
I just used them to lift my bus tires a foot off the ground a few months ago.
My suspension only had 8 inches of drop from full compression. So yes I could use them to change a tire.
You could also add limit straps from the axles to the frame. They use them alot in the 4x4 industry. The limit straps look like big seat belt straps.
Old 12-20-2015, 10:49 PM   #22
Engine: Int. DT466
Rated Cap: 35
what is the model # on those bulldog jacks? do they have an axel that connects each pair so they lift in tandem? and if so, can that axel be disconnected?
thanks
kyletheyeti is offline   Reply With Quote
Old 12-21-2015, 07:33 AM   #23
crazycal's Avatar
You want them to lift separately.
I'm hungry!
You Gotta Let Me Fly
Old 12-21-2015, 11:33 AM   #24
Engine: Int. DT466
Rated Cap: 35
not necessarily.
