Old 08-24-2017, 01:34 PM   #1
cschuck3's Avatar
Engine: DT360 Diesel
Stealthy Hammock Setup
So has anyone setup a Hammock on the side of a BUS??
I'm looking for a low profile/stealthy setup/solution, I have attached images of the two hammocks, I need setup and a solution suited for both. I only want to use the Hammock and not the metal frame which I am planning to find a solution that will be fixed to my bus?
cschuck3 is offline   Reply With Quote
Old 08-24-2017, 02:29 PM   #2
Njsurf73's Avatar
Chassis: Bluebird
Engine: 5.9 Cummins 24v
Rated Cap: 72 pax
One side of the hammock can attach to any point on the bus. And use a spiked pole for the other side..
Or make 2 arms that attach to the bus and hang it alongside the bus, almost like an awning set up.
Just off the top of my head.
Home Depot sells fence post spikes that go on the bottom of a 4x4 post... That could be the side that goes in the ground.
Old 08-24-2017, 03:02 PM   #3
cschuck3's Avatar
I wanted to avoid the following!!
I want high off the ground, I think LOL
Old 08-24-2017, 03:25 PM   #4
Njsurf73's Avatar
Chassis: Bluebird
Rated Cap: 72 pax
Why not use the metal poles and set something up on the roof?
Old 08-24-2017, 03:28 PM   #5
cschuck3's Avatar
I'm thinking that but I don't want it to look to crazy, so that's why I was asking for a Stealthy or low profile setup?
Old 08-24-2017, 04:44 PM   #6
stephenbloxham's Avatar
Chassis: 12m (40') coach
Engine: Mitsubishi 16L V8
Some people already think we're crazy for living in a bus. Why let that worry you? A gazebo on the roof and a hammock with a view are a great idea.
Sent from my SM-G930F using Tapatalk
stephenbloxham is offline   Reply With Quote
