Old 04-16-2016, 12:21 PM   #1
Chassis: IC CE
Engine: T444
Tank-less LP water heater?
Is a tankless water heater a better option than a 6 gal water heater? A few units seem similarly priced between the two.
Azuleslight is offline   Reply With Quote
Old 04-16-2016, 03:20 PM   #2
Robin97396's Avatar
I guess it depends on how much hot water you need. The 6 gallon water heater will take a bit of time to recover, but on the other hand 6 gallons is a lot of hot water. The tank-less units vary widely in price but are supposed to supply a steady stream of hot water for as long as you need it. If it can heat 3 gallons of water per minute I'm pretty sure that's all you'd need. I forget how the ratings are on the tank-less heaters.
Old 04-16-2016, 04:09 PM   #3
dredman's Avatar
I have a tankless, and I will NEVER have anything else - it is awesome, not sure why anyone gripes about them? I guess they want to constantly boil water and heat up the house, burning gas all the time?
My 3 Year Adventure
dredman is offline   Reply With Quote
Old 04-16-2016, 05:08 PM   #4
Robin97396's Avatar
I have two propane household sized water heaters I bought some years ago that are in storage. Vent that into the bus as a source of heat, and a big tank of hot water to boot.
Yes there's the venting issues, but with propane there are always venting issue to get rid of the moisture. Close your top hatch on a wooden cooking spoon and it works fine. For a couple months this winter I needed some real heat to compensate for all this glass while it's freezing outside. I'd really like a floor heating system and some people use dedicated tankless water heater in a floor system.
Old 04-16-2016, 08:45 PM   #5
Alan N's Avatar
Year: 1975
Chassis: Gillig
I agree. I don't know why anyone would use anything else.
Unless you like running out of hot water during your shower.
Alan N is offline   Reply With Quote
Old 04-16-2016, 09:14 PM   #6
Chassis: IC CE
Engine: T444
sounds like tankless is the way to go then. I will start researching them now , thanks!
Old 04-16-2016, 09:23 PM   #7
Robin97396's Avatar
For anyone with experience with the tank-less water heaters, what are the most dependable brands and how much output is needed?
Old 04-16-2016, 10:35 PM   #8
Chassis: IC CE
Engine: T444
ALL OF THIS ^^^^^^^^^ up here!
Old 04-17-2016, 05:38 AM   #9
superdave's Avatar
Chassis: thomas
Engine: 8.3 cummins
Rated Cap: 11 window
this is what ive used for 2 years, no problems. im getting the l10 for my home.
Eccotemp L5 Portable Tankless Water Heater - 119693, Portable Toilets & Showers at Sportsman's Guide
my build pics
Old 04-17-2016, 09:02 AM   #10
Docsgsxr's Avatar
Engine: Cat 3126b 250 HP
Rated Cap: Only 1 seat
Do you use the shower head that comes with it, or have you hard plumbed it into your current system? I'm just wondering about hot water for my sinks as well.
-Doc
My build thread - viewtopic.php?f=9&t=467197
